DEF PROBLEM
Discussion in 'Freightliner Forum' started by 294dave, Jul 18, 2020.
  1. 294dave
    294dave Bobtail Member
    13
    gretna,La
    I have 2013,CASCADIA,EPA10.DD15.. I had five different SPN codes pertaining to deaf system the def pump was leaking so the def pump is change the metering valve was change all the heater lines change fresh DEF fluid and limiting air valves change codes cleared,New updates on 3 ECM computers.Trk Ran fine for one day all the codes came back all three check engine lights back,I done couple regens,also fine reset..Nothing. need help please
  3. TokyoJoe
    TokyoJoe Road Train Member
    1,077
    3,667
    Feb 10, 2015
    I had a 13 back in 15-16. Once it got to 450000 or so miles I had all kinds of def codes , all the time. Lost power, smelled like piss in the truck, sometimes the codes went away but they always came back soon.
    Amarillo FL said they fixed it, they didn't, Fontana FL had it for a week and said they fixed it, they didn't. Finally KC FL replaced a major wiring harness and that did it and I didn't have anymore def issue. The mechanic told me that those wiring harnesses are too close to the underside of the engine (I think) and they get burnt or melted.
    Anyway a month or 3 later the entire transmission suicided so I never drove that truck again.
  4. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    What are the fault codes? What is the last six digits of your VIN?
    RocketyMan Thanks this.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Yup, repaired my wiring harness also.
    It runs from the One-Box , over the top of the transmission and down to the Aftertreatment Control Module.
  6. 294dave
    13
    gretna,La
    Vin..BR4867..CODES ,SPN 4364 FMI 18,SPN 3364 FMI 2,SPN 5397 FMI 31.
  7. uncleal13
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Low NOx efficiency, poor def quality, too many regens.
    The first and second codes are likely the result of the third code. Could be DOC face plugged.
    Are your Jake's working fine? If not , it can cause incomplete regens.
    QUALITYTRUCK Thanks this.
  8. 294dave
    13
    gretna,La
  9. 294dave
    13
    gretna,La
    Yes my Jake's are working fine Freightliner had taken a look at it they trying to tell me the one box another shop said maybe ACM going bad..Not sure what to believe..Regen working fine.
  10. Brandt
    Brandt Road Train Member
    4,402
    5,933
    Sep 17, 2012
    Hope it's not the One Box thats very expressive. I had 2011 Freightliner and the low Nox conversion. They replaces sensor but in the end the DOC filter went bad. They are built into the One Box and can't be replaced.
    294dave Thanks this.
  11. brysol01
    brysol01 Medium Load Member
    312
    445
    Nov 2, 2009
    You need to check up the post from MYHM, when you get a chance ity will save you thousands!!
    Its your NO x sensors, Freightliner can not duplicate what your truck does out on the road with their
    computer, Oh, its not tghe NO x sensore they say, change both , let the outlet one hand out in the fresh air
    problem solved
    294dave and roshea Thank this.
