My truck stopped running yesterday after running rough. It happened pretty fast.
Mechanics state that there was a lot of DEF fluid in the diesel and that the only way for it to get there was to be pumped into the tank. The truck is a 2013 Freightliner. Since I didn't pump the DEF into the diesel tank, is there another way for this to occur? Was I sabotaged? Was it all just some black magic?
Please inform me...
DEF in my diesel? How did this happen?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DocWatson, Dec 22, 2015.
Page 1 of 6
Someone at the shop put it in there to run up your bill???
DocWatson Thanks this. -
There's another thread on this posted some time ago only he put def in the fuel tank.he was down for days.cost a bundle to fix because he drove it for miles before it finally quit running.
My truck was running kind of rough a couple of days prior. I've had issues with this truck in the past with rough driving and a check engine light that is never fully addressed by my mechanics. The previous driver whom drove this truck had the same issues. I was told, when I get the check engine light, to just keep resetting the power switch (that little switch on the Freightliners near the driver's seat that shuts off all power to the truck). I was told to flip it off for about 30 seconds at a time, do it about 3 times and see if that fixed the check engine light issue. Most of the time it worked. My mechanics were aware of this issue with my truck.
A few days ago when my truck was running rough it felt like it needed a regen even though I didn't get a regen light on the dash. I pulled over, tried a manual regen and the truck didn't regen. I shut if off and let the truck sit for a few minutes. When I started it back up it ran fine. I marked it up as just another quirk with this truck. It has a few including those I listed already plus my Jake break magically turns on when it wants to. It's a fun truck. -
I read a service bulletin, and the way they determine this is to check the water separators. There will be a strong odor of ammonia, and the separator will be overwhelmed by the amount of def, which is about 2 thirds water and is heavier than fuel.
It doesn't take that much given the size of the filters involved. Tanks need to be thoroughly cleaned and purged and pretty much the whole system must be replaced.DocWatson Thanks this. -
This whole thing concerns me though. For one, they say they don't have a replacement truck for me to drive currently as they are giving the available trucks to those coming out of orientation. Second they said they won't pay me breakdown pay (which really isn't anything anyway) until the "investigation" is complete.
Page 1 of 6
