Def filter removal on a 2019 Peterbilt with a Cummins.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Z800xp, Feb 11, 2021.
  1. Z800xp
    Z800xp Bobtail Member
    20
    Feb 26, 2019
    How does the Def filter come out on 19 peterbilt cummins. I cannot twist it and can't pull it out. Doesn't come with a tool either.
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Not a pete, but this guy does a good at the job. Same pump thats used on 2017 and newer Pete and KW.
  4. Fieldrat
    Fieldrat Bobtail Member
    43
    67
    Jan 31, 2021
    Big pair of channellocks or knipex pliers to twist. They are usually pretty tight. The new filer should have the new plug too. The old filter should pull out, sometimes they can be kind of stuck too if there was a lot of restriction.
    If changing due to contamination you should flush system with distilled water
    If changing because of a contamination issue, you should flush the system with distilled water
    Reason for edit: Illiterate
