Dead battery
Discussion in 'Experienced Truckers' Advice' started by VIAJERO1A, Mar 19, 2013.
  1. VIAJERO1A
    VIAJERO1A Light Load Member
    99
    35
    Jul 30, 2012
    Over a week parked and cold weather, and now the battery doesn't have enough juice. Would it hurt my car battery if I give a boost from it? Thanks.
  3. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    Nope will not hurt it, done it but may take a while to build up enough juice.
    VIAJERO1A Thanks this.
  4. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    No, but you will likely need to leave it hooked up for quite a while to get those truck batteries charged up. (Leave your car running, don't shut it off). I would say, you will need to charge the truck at least half an hour, because you are likely charging 3 or 4 truck batteries up, right from dead. You can check your voltmeter in the truck from time to time to see how the charge is going, and leave the car hooked up and running when you try to spin the truck.
  5. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    if the batteries are in good shape. and you have good cables and charging system. i've done it in 5 minutes. -10 and a shot of ether.
    if your battery is in good shape. that's 500 amps. to get your truck going. but if you can. 2 cables would help a little faster. one cable also has a tendency to heat up. (if your truck is one that takes some cranking time). unless you got them really thick cables.
    i've got 2 of the skinnier cables sold at harbor frieght on my truck. i've jump started 4 drivers so far in 2 years i've had the cables. after 10 minutes and no cranking. i jump inside the truck only to find out it's in gear. always fires up once in neutral.
    crazy drivers.
  6. ladywrongway03
    ladywrongway03 Heavy Load Member
    766
    328
    Aug 28, 2008
    trotwood oh
    to do it faster I hook up 2 cars to truck
  7. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    If the truck has a clutch, push it in. Sometimes a little less drag will help it turn over when the transmission oil is cold
    :biggrin_25525:
    MJ1657 Thanks this.
  8. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    push start it!
    mp4694330 and Numb Thank this.
  9. truckon
    truckon Swamp Thing
    4,775
    15,915
    Dec 16, 2011
    Like I'd tell you!
    Rev the car engine up to about 3500 rpms while your cranking the truck over.
  10. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    The alternator has a built in voltage regulator. That's an old wives tale.
    chopper103in, j3411 and aiwiron Thank this.
  11. VIAJERO1A
    99
    35
    Jul 30, 2012
    No can do. It's automatic. thx anyway
