DEA500 Radio - How To Tune One Frequency at a Time?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by madmoneymike5, Jan 21, 2020.
  1. madmoneymike5
    madmoneymike5 Medium Load Member
    633
    283
    Jan 30, 2010
    Arlington, TX
    So I drive a Cascadia with the DEA500 radio. Often times there are "traffic information" radio stations (ie 1610 AM), but I'm unable to tune directly to that frequency. The radio seeks to only strong signals and won't let me tune the frequency up or down one interval at a time. Happens on FM, too.
    Any suggestions? What button am I not hitting? (I've hit them all, but you know, maybe I'm not holding my tongue just right.)
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    I think thats the same radio in my pete and if you hold the seek button it will move one feq at a time.
    madmoneymike5 Thanks this.
  4. JGunner
    JGunner Bobtail Member
    14
    18
    Oct 26, 2019
    Those radios are great. Listening to phone on normal volume via Bluetooth. Shut off truck, phone disconnects; deafening static upon starting truck.
    Upinsmoke and Crude Truckin' Thank this.
  5. madmoneymike5
    633
    283
    Jan 30, 2010
    Arlington, TX
    This was the ticket! I thought I'd held it down long enough, but ####, you gotta hold it down for like 3 entire seconds just to switch the frequency 1 time. That's a dumb design. It should be the other way around. Single press to tune one frequency at a time, hold it down to scan.
    Thanks for your help!
    Upinsmoke and Roberts450 Thank this.
  6. tscottme
    tscottme Road Train Member
    I have the same radio. You can choose what the "tune up" and "tune down" buttons do. The default is a quick press scans to next station above a signal strength setting. You can either change the setting by pressing the multi-function knob and digging through the setting. Or you can press and hold the tune button for a few seconds and it will jump 1/10th of a frequency. For example, move from 89.1 to 89.2. In the setting you can reverse that behavior where each press would cause freq to change by 1/10 unless you press & hold which would scan to next sttong station.
    Upinsmoke and madmoneymike5 Thank this.
  7. madmoneymike5
    633
    283
    Jan 30, 2010
    Arlington, TX
    Thank you! Thank you! Thank you!!!
    tscottme and Upinsmoke Thank this.
  8. Driver number 9
    Driver number 9 Bobtail Member
    Dec 5, 2021
    Ready, push and hold volume knob til it says “speakers” then turn knob til it says “ tune CFG” then hit volume knob once and it will say “ tune auto” then turn volume knob one click til it says “ tune manual “ then hit volume knob once. You’re in manual
    P60608 and MidWest_MacDaddy Thank this.
  9. DevorahDrives
    DevorahDrives Bobtail Member
    Whenever my truck starts it restarts the radio and automatically goes to the wx channel at the volume I had whatever I was listening to last. Is there a way to set the default source on power up?
