Looking at a '93 KW, has 12.7L 60 Series, 425hp. I know they switched from DDEC II to DDEC III around this time. Anyone know which one would be in a '93 model truck? What are the differences between the two as far as reliability and fuel mileage? I searched and everything Detroit related seemed to be addressing newer models. Thanks for the help!
DDEC II vs DDEC III
Discussion in 'Trucks [ Eighteen Wheelers ]' started by See Are125, Nov 11, 2013.
They started using DDEC III in 1992 so that's what the truck should have come with from the factory.
Edit:
Just remembered that there was a 92 or 93 kw with a series 60 in it that I worked on that had DDEC II, I believe you can tell what version it uses by the part number on The ECMLast edited: Nov 11, 2013
See Are125 Thanks this. -
Thanks. I knew it was sometime around then. I figured there might have been a transition period where both engines would be available in the same model year truck. Similar to how you can get pre-emission and emission engines in 07 trucks. Any huge differences? Would one be preferred over the other for any reason? I'm new to Detroits.
I have a '93 Kw W9 made in June of '92. It has a DDEC II in it. It has had a few simple mods. done to it. It isn't a big CAT but I like it for the fuel mileage and the parts are pretty cheap.
I did it. Deec-II to DEEC-III swap... works well
there are some old MAZ trucks here with Series 60 (Euro-II emission). If DEEC-II fails u cant find it on JY, so I used to rewire and install DEEC-III ore DEEC-IV ECMs. But sometimes boost pressure sensor ore ECT reads wrong data and I used some sensors from donors.
DDEC-II is made before flash appeared, this unit is not so flexible like DDEC-III and later.
If or when a ddec II fails most shops will upgrade to a ddecIV because it is hard to find an ecm. And Detroit does not support DDECII anymore.
