DD15 wont fire after fuel filters changed.
Discussion in 'Ask An Owner Operator' started by MTMAUS, Aug 4, 2023.
  1. MTMAUS
    MTMAUS Light Load Member
    222
    175
    Sep 28, 2019
    Firstly, i have changed fuel filters on this truck before and am well aware of the issues you have with priming them, but this one has me beat
    Changed fuel filters on a 2017 DD15 with the 2 fuel filter set up plus the water seperator. Primed the system as I always do with the primer, pumped it a good 1000 times. But man this thing wont fire.
    After turning it over I checked the main fuel filter and its pretty much empty.
    Spoke to my mechanic who gave his air pressure fuel primer, a little home made portable thing, it made no difference.
    It will fire on brake cleaner for 2 secs before stopping.
    I opened the second small filter and primed it with the cap off, but full of diesel until the air bubbles stoped coming through, then some more pumping.
    It doesnt even try and fire, nothing close except for using brake cleaner.
    Am I at the point of towing it to a shop?
    Any other things I should be trying?
  3. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    I've only owned my truck enough for 1 fuel filter change. I had the dealer do it. Because I'm terrified of this exact thing.
    All I can ask, are the O-rings in place? Pull the filters and check for blockage in the filter housings. Maybe a work rag fell in.
    Good Luck.
    Constant Learner Thanks this.
  4. LameMule
    LameMule Road Train Member
    1,147
    7,399
    Jan 19, 2020
    Montana
    They don't run on air. Some guys have to prime the system with a hand primer or get creative and vacuum the air out. There's plenty of videos on the youtubes about how to prime the fuel system.
  5. MTMAUS
    222
    175
    Sep 28, 2019
    Pulled them all off and checked them, cant see anything wrong with them. No bubbles in the water seperator when cranking.
    Two things I noticed, after cranking sometimes the hand primer is doing nothing like its got no fuel on either side so its just pumping air, when I fill up the filters though it pumps fuel.
    2nd on is, the level on the water seperator doesnt change when cranking, I thought it usually goes down when crankong whilst its full, but maybe I am wrong on that.
  6. MTMAUS
    222
    175
    Sep 28, 2019
    When I watch videos of it, everyone talks about the fuel primer getting stiff, or when using the pressure systems that they stay pressurized, my hand primer never gets stiff (even before when I primed successfully) and when I put pressurized fuel into the port it just takes all of the diesel (about 3litres) and it just seems to pump it through
    Am i missong something?
  7. LameMule
    1,147
    7,399
    Jan 19, 2020
    Montana
    A "tech" told me that it can require 300 plus pumps on the hand primer for a dd15... if that's true or not I have no clue but in my experience if you don't get the hand primer to start to feel like there's serious resistance or pressure then you're gonna have a rough start if any at all and that's with a much older injection pump, not with the higher pressure injection pump like you have which is likely much more finicky in terms of air in the system or low feed pressure.
    Are you cracking a bleeder to release the air while hand priming? It's vitally important in the equation.
  8. MTMAUS
    222
    175
    Sep 28, 2019
    No one has ever told me I needed to do this on a DD15, where is the best place for this? I did yse to do this on my iveco, but i havent seen it done on a dd15?
  9. LameMule
    1,147
    7,399
    Jan 19, 2020
    Montana
    I have no clue on a dd15 but if it were me I'd be making sure when I pumped the primer that fuel was making its way to the inlet of the injection pump or as close to it as practical for checking. You could be pumping/priming against a cushion of air trapped in the line to your injection pump for all you know. I don't know much about the dd15, but I do know a diesel isn't gonna start on air!
    How long are you cranking the engine over for while trying to start it?
  10. MTMAUS
    222
    175
    Sep 28, 2019
    A good 10sec, whats the maximum I can go?
  11. LameMule
    1,147
    7,399
    Jan 19, 2020
    Montana
    Til your starter overheats or your batteries give out.
    Last Call, Opendeckin and Cattleman84 Thank this.
