dd15 valve chatter, faulty heads?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by wtokhi, Feb 9, 2020.
  1. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    hey ya'll,
    im posting this just out of curiosity, recently in our shop we've had a lot of dd15 engines have a lot of valve chatter and upon opening the top the intake valves always seem to be too tight, the sound goes away after adjustment but just 5,000 miles later the truck is back with it, they tighten up back and its almost gettin to the point of no more adjusting screw left, always seems to be on the intake valves, this isnt just one instance, we've been having a lot of customers come in with this problem recurring, just a couple days ago i noticed one engine sounded as if one or two pistons were completely off the same noise you'd get from a cylinder cutout kinda like a heavy piston along with valve chatter, took off the top and sure enough the intake valves were too tight and the sound was possibly one stuck open slightly, does anyone know if these heads are faulty or am i the only one going thru this, its all different trucks? throw ur opinions and experiences out here, thanks!
    Roadking96 Thanks this.
  3. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    what model years are these engines?
  4. wtokhi
    251
    115
    Nov 3, 2017
    id say 2011 to 2013, but i dont remember exactly but i know two of em were 2012's
  5. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    these trucks are line haul trucks or they do sand/dirt hauling?
  6. wtokhi
    251
    115
    Nov 3, 2017
    just line haul, far as know dry van
  7. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    it's called intake valve recession. Detroit Diesel knows about it. Sometime they change the head under warranty. Nobody knows why this happens. I have seen only one engine with this issue and it was 2016 my engine...
    devedo and baha Thank this.
  8. wtokhi
    251
    115
    Nov 3, 2017
    was it a recall or something? do you know where i could get more info?
  9. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    Go to Detroit Diesel dealer and talk to service department … No, there was no recall issued for this problem.
    wtokhi Thanks this.
  10. wtokhi
    251
    115
    Nov 3, 2017
    sure thing, thanks!
    mhyn Thanks this.
