Ok I need some input on this from you guys ...how many miles do you guys out there run a 2012 Cascadia with a DD15 before an oil change is recommended, along with changing the 3 fuel filters? The reason I'm asking is because I was talking to a trucker and he changed it every 45,000 to 50,000 miles and I've been changing it every 12,000 to 14, 000 miles. I also made sure he wasn't using the synthetic blend but Nope he said straight Shell Rotella from Sam's Club. Am I changing it way too early? I got the 12,000 to 14,000 miles range from the service dept at a Transchicago group in Elmhurst. Now I drive the truck mostly on highway pulling a flatbed locally in Illinois and surrounding states. This guy just kind of thru me off with the range and he didn't seem like one of 'them' guys that seemed out of whack ...he looked like he knew his stuff. Any input is welcome ...thanks guys
DD15 oil change/fuel filter interval
Discussion in 'Ask An Owner Operator' started by TRS Group, Oct 15, 2019.
Detroit says 50,000 miles I was doing mine at 25,000 miles sampled a few times and it came back clean... my worry was if a injector started leaking I was scared of damaging the engine running it so long..
Jarhed1964 and Farmerbob1 Thank this. -
with shell t4 he could probably go that long
Jarhed1964 Thanks this. -
I have a DD15, 2016 model Freightliner, and what I am starting to do is get oil samples done every 10k miles or so.
Two oil changes back, the shop put 5w30 full synthetic in the truck, instead of 10w30 semi-synthetic. After 15k miles, there was some fuel mixing in the oil. I changed the oil at 20k, and put 10w30 semi-synthetic back in it. After 15k more miles, I got a new oil sample taken, AND changed the oil again with 10w30 semi-syn to be sure I got rid of the majority of the thinner full synthetic oil. From this point forward, I will be getting oil samples taken at 10k or 15k intervals, and change the oil at the first sign of degradation.magoo68 Thanks this. -
How would semi synthetic lesson fuel contamination? What am I missing here?
When I get the current oil test back, there's a good chance that it will indicate fuel buildup in the oil again. If that's the case, I'll need to start thinking about some engine work.
I don't think it will. The truck burns zero oil. Never has. I think the thinner oil simply allowed a bit more fuel penetration past the cylinder rings.Jarhed1964 and starmac Thank this. -
I find this fairly simple.
Hook up with an oil analysis lab, and sample every 10k.
Learn about oil.
Change your oil when the analysis indicates it is time to do so.Farmerbob1 Thanks this. -
I have the dd13 and I change (bulk oil) every 10-12k miles.
Changing your oil on dd13/15 every 10 to 15000 miles is a waste of money. These new technology engines are designed to go 36k to even 45k which some of us don't tk that kind of chance once the warranty goes out. I just sold a isx 870 with 1m 200k and changed the oil every 20k miles and that engine didn't have a blow by or used 1qt of oil. The main thing on these dd engines is to do premaintenance. Def filters and clean the injectors. Change your Dpf filters and change your inlet and outlet nox sensors. Check your plastic interfender on both sides and make sure they are not rubbing against your bunk water lines and especially the drivers side where the Airlines run right up against the fenders. Believe me cut a notch out of the fender bc it will cut that Airline. Don't tk your truck to freightliner if your city horn stop blowing. Tk the big cross section that holds your horn botton up and turn it over. There's a wire that will pop loose from the horn button on the bottom. Push the wire back in and push the horn button and wala your horn blows again. Mailman
Diesel Dave Thanks this.
