Dd15 no start without starting fluid
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Transportauto, Feb 3, 2024.
  1. Transportauto
    Transportauto Light Load Member
    100
    34
    Apr 10, 2022
    Got a 16 cascadia dd15.
    After the truck sits for 10 hrs or more the truck will not start without starting fluid.
    Can prime the fuel system 1000 pumps makes no difference, it's been doing this about 2 months now so we know it simply takes a very very small spray of starting fluid and it runs like nothing happened.
    No voltage issues no codes, no metal in the fuel filters.just don't understand its almost like the engine needs that jump in rpm to trigger the injectors to fire.
    Any advice is appreciated
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Perhaps a suction side air leak in the fuel lines from the tanks to the fuel pump. If may be a large enough leak that the hand pump cannot over come it, but small enough that once it is running the main pump has enough suction to overwhelm the leak.
    If your truck has the fuel shutoff valves, I had a seal leak on one of the valve stems due to the weight of the hand control rods that go to the actual valve pounded out the stem from the side loading on it.
    Oxbow and 062 Thank this.
  4. 062
    062 Road Train Member
    6,143
    33,179
    Oct 20, 2013
    Does it have a davco?
    If so,fill it up and see if it drains in about 10-15min.
    Did this start after a filter change?
    Oxbow, JB7 and Magoo1968 Thank this.
  5. Antinomian
    Antinomian Road Train Member
    2,076
    3,242
    Feb 17, 2013
    Sounds like a bad Davco check valve. If so they are about thirty bucks and can be changed in about ten minutes.
    See if the filter is empty after ten hours of sitting. It shouldn't be.
  6. Transportauto
    100
    34
    Apr 10, 2022
    It's not a fuel leaking issue, got pressure as soon as the engine turns of I believe 70psi (have to go look at my notes)
    Thing is once you give it the slightest spray of starting fluid and the engine picks it up and the rpm bumps up for that split second to around 600 rpm or so it fires and immediately runs normal.
    It's almost like the ecm doesn't fire the injectors until the truck has that rise in rpm from the starting fluid. Definitely a Strange situation but I do know it's not a fuel loosing prime situation also I can watch rpm on diag link while cranking,
    You can prime this thing all day by hand or pump, you can spin it until the Batts die but no start without the slightest starting fluid
  7. JB7
    JB7 Medium Load Member
    648
    900
    Dec 13, 2022
    Laurel, MD
    Have to have software to get the data for something like this. Key on engine off, what are the sensors reading, injectors..... What is everything reading while cranking and the truck does not start. What changes when ether is used and the truck starts? Not all problems set a code, even electronic ones. It may be that it only happens after the truck sits for 10 hrs because it cools off. I would also take the connectors apart at the sensors such as the crank and cam sensors and look for corrosion. Other than that get the software version on the ECM checked and may have to have the ECM flashed for updates and the most current version. And always check for service bulletins.
  8. Antinomian
    2,076
    3,242
    Feb 17, 2013
    I'm still thinking it sounds like a fuel pressure leak.
    There is a pressure relief valve on the end of the fuel rail. Those go bad sometimes. I don't remember what they cost but it isn't much. It's also possible an injector could be leaking. You would catch that with an oil analysis. There is a check valve in the fuel filter module also.
    Did you say you have the DDDL software? There is a fuel system integrity test you can run. It measures the fuel pressure leak down rate after you shut the engine off. If you take it to the dealer with this complaint that is most likely the first thing they will do.
    Magoo1968 and JB7 Thank this.
  9. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Mines in the shop for high fuel pressure bleed down when shut off . It throws a code for it spn1077 fmi14 . Also my oil level went up that’s why I put it in the shop on the road . It runs perfect otherwise.
