DD15 just shut off on me Eng 1 fail 16 spn 157
Discussion in 'Ask An Owner Operator' started by TRS Group, Nov 1, 2019.
  1. TRS Group
    TRS Group Light Load Member
    93
    117
    Sep 24, 2018
    Everything was fine then on the expressway then truck turns off, orange check engine light comes on and I get the Eng 1 Fail 16 Spn 157. The truck will not start and I cannot get the fuel pressure up, I've tried pumping the fuel with the thumb pump. It acted up about an hour ago when it hesitated to start, it has fuel about a quarter to half tank on the driver side and very low on the passenger side. What the hell?!! It says something about the limiting valve on the fuel rail and I close??
  3. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    what year is your engine?
  4. Tx Countryboy
    Tx Countryboy Road Train Member
    1,968
    4,437
    Sep 18, 2019
    Low fuel pressure. Sounds like drawing air out of right tank.
  5. TRS Group
    93
    117
    Sep 24, 2018
    2012 Freightliner Cascadia
  6. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    take a look on this doc
  7. TRS Group
    93
    117
    Sep 24, 2018
    Would that be an issue with the fuel splitter?? I have noticed that fuel tends to jump around from one tank to another on different occasions
  8. Tx Countryboy
    1,968
    4,437
    Sep 18, 2019
    I drove a 2013 t660 & it always sucked more fuel from right side tank than left.
  9. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    op how many miles have your truck ? original fuel pump ?
  10. TRS Group
    93
    117
    Sep 24, 2018
    649,000 miles and I believe it is the original fuel filter
  11. Tx Countryboy
    1,968
    4,437
    Sep 18, 2019
    If right tank out of fuel will suck air.
