DD15 HP ratings
Discussion in 'Freightliner Forum' started by ManilaButton901, Feb 8, 2022.
  1. ManilaButton901
    ManilaButton901 Bobtail Member
    11
    May 17, 2018
    Please forgive my ignorance, but I’ve searched the forum and have been unable to find an answer, and you can’t learn without asking questions. Can someone please explain to me how the DD15 hp rating works? Why do you always see trucks for sale listed at 455 hp but looking around on the forums here, I’ve read that all the engine covers say 560 hp? The DD15 brochure has a chart with the different hp ratings on it.
    Why is this? Aren’t all DD15s the same? There’s nothing to differentiate between them. Aren’t they all the same displacement, same bore, same stroke? What creates the differences in the hp rating? Is it just the ECM? Can all DD15s handle 560hp without changing any hard parts?
    Here’s a hypothetical. Say I have a DD15 rated at 455 hp. What do I need to do to get it to 560 hp, just get the ECM files changed if it doesn’t require any hard part upgrades?Let’s also look at the inverse, say I have a 560 hp and want it turned down for whatever reason, maybe I’m hiring a driver or something. If it is just the file in the ECM, does it go both ways, it can be turned up or down, or would hard parts need to be changed either direction?
    If you’ve made it this far, you’re probably now just as confused as I am, but it’s something I’ve been curious about for a while now. Any input would be appreciated!
  3. RocketyMan
    RocketyMan Medium Load Member
    549
    336
    Jun 5, 2015
    Couple of things....
    It's not an "ECM" on the DD15, it's an MCM.
    Next, there is no difference in terms of the software on the MCM, but rather the configurations or programming of the Power Train. There are some options denoted as "driver incentive/rewards" programs that will allow higher HP ratings. One example of this is low power only, high power only, cruise power, etc. These are ordering options that some customers want on their vehicles to give drivers a "reward" for using cruise control that offers a higher "HP" rating while some settings to try and save fuel costs all the time.
    Ssgtkevin and ManilaButton901 Thank this.
  4. ManilaButton901
    11
    May 17, 2018
    Thank you for your response! I apologize for using the incorrect nomenclature, but now that I know what it’s referred to as, that will probably help to narrow any further searches I make about this.
    Since those are options that are selected at ordering, is it possible to change them later? Who can do that sort of thing? If I own the truck, can I just whip into a Freightliner shop and have them change the configurations, or is it more specialized?
  5. Brandt
    Brandt Road Train Member
    4,405
    5,939
    Sep 17, 2012
    Company like Pittsburgh Power have tuner programs for truck engine. Not sure what they can do for the DD15. Some limitations are fuel injectors
    ManilaButton901 Thanks this.
  6. RocketyMan
    549
    336
    Jun 5, 2015
    Depends on what truck you have. Sometimes you might have to do a CWO to get the change. Some indy shops might have their own methods for effectively "flipping a bit."
  7. msh
    msh Light Load Member
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    forget about label on engine. it's max designed hp . hook up the dddl and go to ratings. mostly you will see 455, 475. the highest i have seen is 505 hp.
    there was a talk about dd15 ratings at dtnasolution and i remember one of Detroit's engineers told technicians the onebox and whole aftertreatment system can't handle emissions when engine is in max (560hp) stage.
  8. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    560 hp was a older version I believe any within the last 3 years are topped out at 505 hp 1750 ft/lbs I may be wrong though . Ps on warranty you’re very limited to hp setting without huge costs.
  9. LoneRanger
    LoneRanger Road Train Member
    3,661
    9,445
    Jun 3, 2018
    I only have 2 settings on mine, 455hp or 475hp. If that helps.
    2013 DD15 with direct drive tranny 2.64 gears.
