We just purchased a 2012 cascadia with a dd15. We're brand new to this whole def thing. Can anyone tell me what these codes mean.
Spn 520702 fmi 4
Spn 523531 fmi 31
Spn 2567 fmi 0
Spn 4335 fmi 1
Your response is greatly appreciated
DD15 codes
Discussion in 'Freightliner Forum' started by Gear shift, Aug 26, 2019.
You might want a look into getting code reader software, It's not that expensive and can be extremely informative.
After purchasing the truck, How long did the truck run before these error codes comes on ?
520702 is a light, not sure which one, maybe in cab, maybe outside
523531same as above. If all your lights are working then ignore these two.
2567 is a cluster communication error. no big deal, check cluster harness in back of the cluster.
4335 fmi 1 is the bad one
Diesel Exhaust Fluid (DEF) Air Pressure Not Detected (From Vehicle Supply). 25% Derate.
Could be DEF Metering unit, pressure sensor, pump
See attached diags.Attached Files:
EPA07 10 GHG14 DDEC VI 10 Electronics and Troubleshooting Manual (DDC-SVC-MAN-0084)_ (1).pdf
- File size:
- 470.6 KB
- 68
m2Tim Thanks this. -
