Dd15 codes P77, P78, P114, P373, P418
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by free2fly973, Jun 3, 2021.
  1. free2fly973
    free2fly973 Light Load Member
    95
    11
    Mar 9, 2012
    Oklahoma
    As title says I have these active codes on a 2014 western star 4900SF (FR8686 last 6 of VIN). All mode 5. These are ¾ of the codes that would suggest a bad RX Module.
    Replaced RX Module, which got rid of the P171 5 code. These codes are showing active. The module is an updated module, according to freightliner. Purchased from freightliner. Old module 06-71342-004. New module 06-94503-254.
    Pics show troubleshooting suggest: refer to OEM. I'm not understanding where to look in the dtnaconnect web site or manuals to find/figure out how to solve these codes, or explain these codes. I obviously have the dddl software and access to dtnaconnect website, but not getting any closer to resolving after weeks of searching.
    Any help will be appropriated. And thanks in advance.
  3. free2fly973
    95
    11
    Mar 9, 2012
    Oklahoma
    No one has any clues to these codes?
  4. Trusty
    Trusty Bobtail Member
    4
    Oct 3, 2020
  5. Trusty
    4
    Oct 3, 2020
    I have exactly the same codes and my check engine light switch on and of.
    Did you solve the problem?
    Thanks
  6. free2fly973
    95
    11
    Mar 9, 2012
    Oklahoma
    Not yet. Haven't found anyone that knows anything about it. I also haven't taken it to freightliner yet though. I try to steer clear of my closest dealer as much as possible because of past experiences.
  7. crusts
    crusts Bobtail Member
    May 20, 2022
    Have the same problem any luck finding out how to fix the problem? Thanks!
  8. free2fly973
    95
    11
    Mar 9, 2012
    Oklahoma
    Nope. I guess no one has any clue. Most of these are associated with rx module and last are axle temps. About as far as I've gotten.
    I need to chase wires for the axle temp codes and see what i find. May lead answer to others.
  9. Varga
    Varga Bobtail Member
    40
    38
    Sep 20, 2018
    What is your axle temperature readings on dddl. ?
  10. free2fly973
    95
    11
    Mar 9, 2012
    Oklahoma
    I don't have a gauge and my dddl expired. I do have sensors in the axles for temps though. Guessing for ECM. I'd like to install a gauge.
  11. Varga
    40
    38
    Sep 20, 2018
    Guessing is get expensive this days. You have to read what is the ecm read . Otherwise just pissing against the wind.
    Maybe you got lucky
