Does the filter just pull out once you get the top cover off? I can’t find anything holding it in, but it seems stuck in there really good yet.![]()
DD13 fuel filter removal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OldeSkool, Feb 22, 2021.
Yes, just rock it a bit. Don’t twist it, there is a plastic protrusion on bottom that can break off.
Friend broke it off, couldn’t find it. Put on new filter. Later on the plastic piece plugged the fuel flow and truck stalled out of fuel. -
The smaller final filter next to it is the exact same setup.
while you have the filters removed, good time to drain out the bowl if you are adept at re priming the motor.OldeSkool Thanks this.
