Dd13 engine reliability
Discussion in 'Ask An Owner Operator' started by united972, Sep 4, 2019.
  1. united972
    united972 Light Load Member
    157
    22
    May 26, 2016
    Hi I’m looking at a dd13 engine 2016 Freightliner Cascadia with 400k miles
    i wanting some help from someone who has driven these how is power reliability with motors and what the fuel milage your getting. I will be hauling 53 dry van East cost. 80k gross
    Below are truck specs
    Detroit DD13 12.8L 450HP @ 1800RPM with Engine Brake Eaton Fuller FOM-15E310C-LAS Ultrashift Plus Transmission
    Balance of Manufacturers Warranties-Additional Warranties Available
    3.42 Rear Axle Ratio, Airliner 40,000-lb. Rear Air Suspension w/ Dump Valve Jost JSK37 Series Air Slide 5th Wheel w/ Dash Mounted Control Valve
  3. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    I can't speak for fuel mileage because I have never paid attention but we have a ton of dd13 trucks at work and I haven't seen any problems with them. A lot of them are slip seated and get the #### beat out of them by drivers that don't care too and they still just keep going.
    bzinger Thanks this.
  4. blue1005
    blue1005 Light Load Member
    157
    87
    Apr 18, 2015
    I have read that after 2013 they have become better. No clue personally as I am curious to this question as well.
  5. DUNE-T
    DUNE-T Road Train Member
    6,874
    16,589
    May 10, 2015
    Detroit, MI
    I personally wouldn't risk getting a fleet truck with that mileage and automatic transmission (no matter the engine). It's gonna be a maintenance nightmare
  6. crucar1800
    crucar1800 Light Load Member
    186
    71
    Sep 21, 2012
    Are you still searching on information?
  7. win-some-loose-less
    win-some-loose-less Medium Load Member
    691
    997
    Apr 19, 2010
    Mount Vernon tx
    I personally like the dd13 better than the 15.. they are both boat anchors in my opinion but hated the 13 just a tad less.. the 13 has more torque also for some reason
    FlaSwampRat Thanks this.
  8. crucar1800
    186
    71
    Sep 21, 2012
    What do you mean by boat anchor?
  9. Montanaland
    Montanaland Light Load Member
    81
    58
    Jun 29, 2010
    H-town
    Well I bought mine (2015) used through ruan truck sales with 467k for $43k. 100k mi later no problems yet. I change the oil religiously and add injector cleaner solution to every 3rd tank of fuel.
    From what I've researched the 13 liter engines have less problems. I've been hauling chemicals in a straight bore tanks with it. The truck took a pounding like a rented companion until I got the hang of the surge. Unfortunately the value of the truck is worth less than a lot of cars on the road but its holding up.
    bzinger and crucar1800 Thank this.
  10. crucar1800
    186
    71
    Sep 21, 2012
    What's your average hauling weight? What your mpg on that dd13? What's the size of your fuel tanks?
  11. crucar1800
    186
    71
    Sep 21, 2012
