Dd13 def issue check engine
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by wtokhi, Sep 13, 2023.
  1. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    Hey everybody
    Have a couple of ghg17 cascadias with Dd13s, throwing code 520372 fmi 16- Selective Catalyst Reduction Closed Loop Control at Maximum Limit. I have had some trucks in the past with this code and changing the def metering unit fixed it but there’s a couple that did not. On those I’ve also changed the def metering unit and both nox sensors, have done all modules software update for fuel map, def system cleaned. There’s a temporary fix of running scr efficiency tests back to back to get NH3 levels but up code will always be back. At a loss of what else it could be, any help appreciated
  3. Gridaxe5588
    Gridaxe5588 Light Load Member
    108
    148
    Nov 23, 2022
    I'm pretty sure it means green house gas
  4. wtokhi
    251
    115
    Nov 3, 2017
    Emission year standard 2017
  5. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    You have gone through the 520372/FMI 16 -GHG17 fault troubleshooting steps? They are pretty short.
    1. Connect with Diagnostic Link
    2. Start ignition (key on, ignition off)
    3. Is ACM software level 7.61.1.0 or higher? Yes go to step 4. No go to step 5.
    4. Is ACM fuel map ZGS 001 or higher? Yes, go to step 6 If no, update using latest server info.
    5. IS the ACM software level greater than 7.60.2.0. If yes got to step 6, If no, update ACM using latest server info.
    6. Are any low battery voltage, DEF dosing, fuel system or engine air management faults present? If yes, fix them first.
    Perform parked regen followed by the SCR parked efficiency test and then diagnose any DEF dosing system faults that sets."
    The fault description says that an additional fault should set identifying the dosing system fault. This is for ACM21T. Or do you have ACM301T?
    Reason for edit: added info.
  6. wtokhi
    251
    115
    Nov 3, 2017
    Yes as I explained, the fuel maps have been updated, there are no other codes logged just that one, regen followed by scr only fixes the issue temporarily, the code always returns
