Daytime running lights
Discussion in 'Kenworth Forum' started by Bean Jr., Feb 7, 2017.
  1. Bean Jr.
    Bean Jr. Road Train Member
    5,468
    9,698
    Mar 30, 2014
    Ok, I bought the truck in Canada. The headlights are on when the switch is on. There are 4 light switches. From left to right cab lights only, trailer lights, headlights and finally tail and side lights. Headlights are always on, but lower than low beam. Turn on either Headlights or tail side lights, tail side lights and trailer lights come on, so it really needs 2 switches, Headlights and cab lights. It has chicken lights, but they were disconnected by the shop because they interfered with turn signals.
    What I want; daytime Headlights off, and all switches only doing 1 thing. Cab lights, fine. trailer lights turned on only by trailer light switch. Headlight switch only turning on Headlights, and finally tail and side only turning on tail and side. I could put chicken lights on trailer switch.
    The question is, how? especially turning off daytime lights.
  3. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Don't know about KW's, but my Volvo has a DRL Module in the Fuse Box that you just remove and the DRL will not turn on, but the Headlights will work normally.
    Dye Guardian and Bean Jr. Thank this.
  4. Bean Jr.
    5,468
    9,698
    Mar 30, 2014
    I don't think this works the same way. I should have given more info. It's a 94 W900L.
  5. 062
    062 Road Train Member
    6,143
    33,166
    Oct 20, 2013
    Should be a relay for the daytime lights,pull it and save for a spare.
    Bean Jr. Thanks this.
  6. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    there is a day time light module in the dash, just unplug it. it is usually found behind the panel next to the glove box and could be Velcro to the bottom of the dash.
  7. Bean Jr.
    5,468
    9,698
    Mar 30, 2014
    I'll check both these suggestions.
  8. Jacoooooooo
    Jacoooooooo Heavy Load Member
    742
    1,049
    Oct 20, 2013
    Can anyone help locating thar module in a Volovo (I have a 2021 VNL760)? I’d like to disable DRL’s. It’s a bad design. All lights come on after wiper use and there’s no way to turn them off without turning the truck off… i checked fusebox and no fuse or relay is described as anything that would indicate it’s for DRL, unless it’s one of the LCM relays, but than I don’t know which one.
  9. 062
    6,143
    33,166
    Oct 20, 2013
    That may be a setting in the ecm.
    @nasriza
  10. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    You need Volvo PTT w/Devtool to change.
    062 Thanks this.
  11. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Need to simply change parameters under light control module, i highly doubt dealers would do it since they are considered safety factors right now.
    Bean Jr. and 062 Thank this.
