Daytime running lights flicker
Discussion in 'Peterbilt Forum' started by Darrylk, Aug 16, 2015.
  1. Darrylk
    Darrylk Bobtail Member
    4
    I recently swapped out the oem headlights with round single LED bulb headlights and now daytime running flicker please help
  3. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Same problem as this owner?
  4. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    What model are talking about? 359? 379? 389? Which lights exactly are we talking about?
  5. Darrylk
    4
    Sorry talking about a 2011 389, the the headlights that come on when the park brake is pushed in
  6. bubbanbrenda
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    I know I'm killing you with questions but is the new headlight an actual L.E.D. headlight or is it an HID or H-4 crystal light with L.E.D.'s in it? Most DRL's are a separate circuit with a lower watt/amp bulb, so that may be the problem. But I would double ground everything, LED's do not like weak/dirty grounds.
    Darrylk Thanks this.
  7. Darrylk
    4
    It is an actual LED light
  8. Darrylk
    4
    Thanks very much I will give that a try
  9. Freightshaker613
    Freightshaker613 Light Load Member
    74
    20
    Jan 5, 2013
    Ontario Canada
    I have those same LED headlamps on 4 different units and all we did is pull the 2 fuses for the DRL one goes to the ignition and the other the batteries (binders) rolled over the plate plenty of times w no DRL on they don't seem to mind much in Ontario. Or you can just pull the fuse(s) when you crawl into the bunk. Hope this helps
  10. thelushlarry
    thelushlarry Road Train Member
    3,023
    8,997
    Jan 9, 2012
    glasgow ky
    Do not run in the day time.
  11. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    Or just turn the headlights on.
