Day Cab maximum load
Discussion in 'Ask An Owner Operator' started by Dlewis48, Sep 14, 2021.
  1. Dlewis48
    Dlewis48 Bobtail Member
    New to trucking. Found a day cab for a steal of a price. The GVW is 65000. What the max load I’d be able to haul.
  3. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    You can haul whatever the legal limit is for your state
  4. Dlewis48
    So this small truck could carry 43000 LB load
  5. abyliks
    abyliks Road Train Member
    3,746
    8,694
    May 2, 2010
    ludlow MA
    Sounds like a single axle.
    ~30k ish depending on several hundred other factors
  6. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    Well is it a tractor or is it a straight truck?
    If it is a 6 wheel tractor you are limited by what you can pull and you can certainly not pull 80,000 pounds.
    And that rating is most likely the combination weight not the GVW.
    Bean Jr. Thanks this.
  7. Don379
    714
    1,286
    Jan 7, 2021
    Bit of confusion here. He said gvw of truck is 65k. Not gcvw.
    Sounds like a tandem. Why else would he ask how much he can haul. So if its a tandem, HE can haul whatever the legal limit for that state he is in. Here in Pa, you can haul 80 thousand with tandem truck and tandem trailer.
  8. Ridgeline
    22,103
    113,210
    Single axle day cabs have a max gvw of roughly 32,000. 20k on the rears and 12k on the fronts unless they are ordered with hd equipment, then the front axle can be up to 18k
  9. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    How many axles are on the truck, is it a sliding fifth wheel?
  10. Dlewis48
    One axel and two axel. Guys what I’m trying to ask is if getting loads what’s the max I could fit in the body. I’m new. A buddy owes me money and he is willing to give me a truck to settle a debt.
  11. okiedokie
    okiedokie Road Train Member
    11,675
    84,523
    Jun 13, 2011
    PNWET
    A 3 axle straight truck/ box?
    '88K100 and feldsforever Thank this.
