Data Link Error
Discussion in 'International Forum' started by MoJazzn, Nov 8, 2020.
  1. MoJazzn
    MoJazzn Bobtail Member
    12
    Dec 7, 2018
    International HX 615, data link error appears on dash when started. the transmission (allison) shows xx on screen instaed of NN. ECM replaced, Body controller updated and TCM checked. Dash Cluster is recommended to be replaced any ideas out there welcomed
  3. AModelCat
    154,534
    Anybody actually test the datalink wires to the nodes and check the terminating resistors before throwing parts at it?
    Snailexpress and Heavyd Thank this.
  4. MoJazzn
    12
    Dec 7, 2018
    not sure about resistors, under warranty except dash cluster
  5. MoJazzn
    12
    Dec 7, 2018
    Drove truck stopped for fuel left engine running, shortly afterwards warning beeps start and cat eyes on allison trans controller. Dash lights on for ABS, trans, data error, eng, wrench inside triangle. The air tank pressure and fuel are the only guages that operate properly. Shut off eng. and resart several times get in gear. Drive short distance and while driving 10 warning beeps sound all warning lights come back on.
  6. Heavyd
    Heavyd Road Train Member
    7,750
    6,184
    Feb 4, 2009
    Datalinks are very hard to troubleshoot. Could be wiring, could be corrupted modules. 80% of the time, it is wiring, but the problem has to be active to properly trouble. When it happens, you can try to pull breakers for electronic modules one by one to see if the problem stops. If the problem fixes itself after a simple key cycle, it is likely a corruption problem from a module. First thing to disconnect is any e-logs or satellite systems.
  7. MoJazzn
    12
    Dec 7, 2018
