If you've tried these 3 options what did you stick with? Does the real time update feature on the Pro option for $149 truly give an advantage vs the Basic $39?
DAT vs Truckstop.com
Discussion in 'Freight Broker Forum' started by rakusa, Jan 10, 2022.
Basic dat. Don't overpay. 14 day rates are meaningless. Had truck stop, wasn't impressed. The same brokers are everywhere
I've used truckstop for many years, running stepdeck.
I don't like their "new" version, I'm unable to search from "anywhere" to "anywhere".
Is it possible to do that on DAT ? -
Truckstop. And primarily have only used the app for the last two years.
Pro option may be important when up to the date information is needed. Running produce, it can help one grab an extra 1k out of a haul…or not. Otherwise count the Reefer trailers at the truckstop and compare from the last time you’ve been there.
If I wasn’t focusing on the harvest volumes I would go basic. You save a small off subscription being OOIDA member. Good luck and stay away from Reefer, nothing but problems. Leave it to me, I’m a weirdo that likes doing it.
Lite bug Thanks this.
