Dash Cams At Loves Worth Buying?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by oneperfectrun, Jul 6, 2015.
  1. oneperfectrun
    oneperfectrun Light Load Member
    131
    47
    Dec 18, 2010
    Fulton, MS
    I've been wanting a dash cam for a while. Are any of the cams from Loves worth purchasing? The Loves I frequent have Garmin, Cobra and Mobile Spec cams. Any input from you guys? Don't wanna waste my points if they aren't worth having.
  3. DUNE-T
    DUNE-T Road Train Member
    6,874
    16,587
    May 10, 2015
    Detroit, MI
  4. w.h.o
    w.h.o Road Train Member
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    Another 1 for garmin, probably the most expensive but still working strong after a year, save my ### once so already paid itself. I got a 32gb card I think and it record around 2 days I believe.
  5. oneperfectrun
    131
    47
    Dec 18, 2010
    Fulton, MS
    Thanks.
    I've never owned or even been around a dash cam. Know nothing about them.
    How do they work, say if I have an event I want to save? Some kind of way to save the last few mins it recorded?
  6. oneperfectrun
    131
    47
    Dec 18, 2010
    Fulton, MS
    Y'all are using the Garmin units that Loves sells, correct?
  7. crxdc
    crxdc Road Train Member
    1,739
    1,202
    Jun 24, 2013
    Las vegas NV
    I have the cobra and its good. I wish i would have sprung for the one with GPS built in but The one I have is decent and not that expensive.
  8. w.h.o
    3,583
    4,094
    Jan 10, 2011
    Chicago, il
    It has a g sensor that go off if it gets shaken hard or aka an accident it will go off. If not, there's a button u push to save the footage so it won't get overwritten. Then either take out the SD card or plug into a computer to see the video, there's also a payback screen on the dashcam but easier if u hook it up
    crxdc Thanks this.
  9. crxdc
    1,739
    1,202
    Jun 24, 2013
    Las vegas NV
  10. oneperfectrun
    131
    47
    Dec 18, 2010
    Fulton, MS
    Thanks for the replies and info guys. I've been wanting a dashcam for a while. This morning I had a four wheeler that came over on me and nearly got into my passenger side front fender. I had enough points so I stopped by Loves and grabbed a Garmin cam. I havn't used it yet.
    tucker Thanks this.
  11. tucker
    tucker Road Train Member
    12,647
    40,422
    Jun 13, 2008
    IN
    I've had the Garmin C 10 since December, I've filmed a tire coming off a pickup and rolling safely down the median between 2 jersey walls.
    And today I pull into a tight Pilot, I saved the 4 minute video just in case, a truck tries to park in a spot, gives up and I EASILY back into it, but the truck on
    My right has damage on the fender, it could be fresh IDK, but the video shows the damage as I set up, and then my awesome backing job.
    oneperfectrun Thanks this.
