D16 engine code 5443 fmi 7
Discussion in 'Volvo Forum' started by Vegas-Rider, Aug 20, 2017.
  1. Vegas-Rider
    Vegas-Rider Bobtail Member
    5
    Vegas
    There is a def emulator in this truck. I just bought it. I am getting the 5443 fmi 7 code. Light stays on all the time. Something to do with def, doser system?
    My big question is, will this affect how the truck is running? It seems to drive OK, but since I just got it, I have no real reference. Would this make the truck be down on power?
  3. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    You need to get it fixed as soon as possible. The engine will de-rate to 5 mph if you don't
  4. Vegas-Rider
    5
    Vegas
    Did you have that happen with this code?
    I drove it about 300 miles and it seemed OK. It made around 20-25psi but did seem like it was down on power, but I have no reference for full power.
  5. Sharky88
    715
    851
    Sep 25, 2013
    Your problem is with the dpf doser injector. It's part of the emissions system the truck will allow you to drive for a while but eventually it will de-rate the motor to 5 mph. I don't think you would want that to happen in the middle of no where or while your in traffic in the big city and need a tow. You have an issue fix it
    KB3MMX Thanks this.
  6. shogun
    shogun Road Train Member
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    I think that's the def pressure is low. Mine used to come on all the time, once a month for a few minutes and I just ignored it, as it would go back off. It happened more often when it would rain. However, if it's staying on, it usually indicates a problem, might need to clean or replace the dower injector as the def tends to crystallize and clog up.
    shreemike Thanks this.
  7. shreemike
    shreemike Bobtail Member
    12
    It comes in the morning when it is cold. I use reset tool and it disappears.
    Comes back in the morning again.
    Looks ok to me
