D13 - Low coolant level without any coolant loss/leaks
Discussion in 'Volvo Forum' started by Pawel-pl, May 3, 2021.
  1. Pawel-pl
    Pawel-pl Light Load Member
    66
    30
    Jul 3, 2017
    Hello,
    In my 780 with D13 engine, the low coolant level started to show up a few days ago. There are no leaks or any coolant loss, so I changed the sensor but the msg still shows up. Funny thing it is showing only when I accelerate.
    Do you guys know what can cause this or how to fix it?
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    You can try 1st to put small amount of coolant in at a time to keep it from uncovering the low coolant sensor when you mash the fuel pedal and when it stops sending the code put a mark on coolant res. to show you how full it should be to fix the problem?
    Rideandrepair Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I had a mystery leak like that. Over several months every time I was underneath greasing the truck I found a loose clamp in various locations. Eventually I got them all and it stopped leaking. Sometimes they leak very little and dry off quick, but eventually they show themselves.
  5. Pawel-pl
    66
    30
    Jul 3, 2017
    There is no leaks at all and the coolant level is good, the msg is showing up on dash. Not sure why
  6. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    Bad sensor wiring harness maybe
  7. Pawel-pl
    66
    30
    Jul 3, 2017
    Got it fixed today, the coolant tank has a ring floating piece with magnet inside, this thing either got dmg, stucked or just old and it stoped floating. After change to another coolant tank, with the same old sensor, all is good and low coolant is not showing up anymore.
    NWAF Thanks this.
