d13 egr valve
Discussion in 'Volvo Forum' started by Haulcomb, Mar 29, 2021.
  1. Haulcomb
    Haulcomb Bobtail Member
    7
    Nov 14, 2020
    Hello
    I have 2015 volvo with d13 engine 656k . I have engine light come on p040200 . I know it's time to replace the egr valve but my question is do I can drive the truck 1k to get home and drop the truck in Local repair shop ? I'm in jacksonville FL I called the dealer and first appointment next week
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Might make it. As long as computer doesn't want a regen. Then you may get derates severe enough to screw up your plans.
  4. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    prob is that there is almost no egr valve availability from oem so you might get more time off than u planned for till they get one in.
  5. uncleal13
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Hmm, I had one fail on a 2006 Mercedes engine. It was stuck closed. Don't know if this would work for you depending on what is wrong with yours.
    I cleaned out the carbon, greased the pivots on mine. Got another two months out of it.
  6. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    as long as its stuck closed you'll be fine.. it may do a 50hp derate
  7. Petro51
    Petro51 Bobtail Member
    5
    Mar 18, 2021
    This abnormal egr flow code ,not sure bad egr valve, mostly caused bad diferential presure sensor , harness water condensation inside venturi , or plugged venturi /egr cooler.
    I would start with the sensor , easy to remove clean check the connector, dont lose the rubber gaskets.
