d13 check engine code Dtc p1130
Discussion in 'Volvo Forum' started by SWTRANSPORTATION, Apr 24, 2019.
  1. SWTRANSPORTATION
    SWTRANSPORTATION Bobtail Member
    12
    Nov 19, 2018
    Hello
    I got this code last month but it's disappear after 2 hours now it's come on again today ,
    I have BOD it's showing code P1130
    Aftertreatment Hydrocarbon Air Purge Valve Stuck Closed ,
    Do you guys can help me , what is needed to be replaced and where is located
    2015 vnl670 d13. 534k
    Thank you
  3. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    proably hydrocarbon purge valve module. AHI module and also regulator for air supply, and also air dryer filter.
    Jack carg Thanks this.
  4. Cheetahrepairservices
    Cheetahrepairservices Bobtail Member
    Do you know whey could cause this?
    ECM SPN 3492, Aftertreatment 1 Air System Relay
    Short circuit to battery voltage, Control wire Aftertreatment Hydrocarbon Dosing Module
  5. RoadtoEmmaus
    RoadtoEmmaus Light Load Member
    100
    44
    Apr 20, 2014
    Hey Naz, hope ur good.
    Question is killing me:
    I have code 1133..so half the people say its an Nox sensor bank 1, other half say its AHI stuck open.
    I changed AHI Mod, regulator, air cartride, and new 1/4" line from regulator to AHI Mod.
    Now it says 1133.
    I checked all manuals and cant find an 113300 . So when I check internet, I get 2 different answers.
    2014 780 with D13....what do you think?
  6. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    something is going on with doser system need to hook up and check whats going on with doser system during regen or you can test out there is a possibility your doser is leaking all the time and not letting it build enough pressure, need to see whats exactly going on during regen and AHI system.
    High Stepper Thanks this.
  7. Artur 1996
    Artur 1996 Bobtail Member
    5
    A friend of mine, also on a Volvo truck, was helped by this site with online manuals:
    Volvo Archives
  8. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    I looked into this site a while back all they provide is impact look up which you really have to know your way around to navigate, use it for parts lookups but as far as anything else goes its a pain to try to get any info for it.
  9. Artur 1996
    5
    Can you tell me more, is the problem in the site or in the repair manual itself?
  10. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    The supposed repair manuals, the people from the site have always been helpfull but the manuals are very hard to find still looking to find actual volvo wiring diagrams with absolutely no luck .
  11. MIg25
    MIg25 Light Load Member
    73
    20
    Apr 10, 2020
    Fort Lauderdale - Florida
    Here is what I found about this issue. I hope it helps.
