D13 2014 vovlo noise
Discussion in 'Volvo Forum' started by 05vnl670, Oct 22, 2018.
  1. 05vnl670
    05vnl670 Light Load Member
    165
    60
    Feb 17, 2013
    Just 2 days ago I noticed that the truck is making some screeching/whistle noise when I accelerate and the turbo gauge passes 1/2 mark. I also hear same noise but not as loud when using engine brake( at this time the turbo gauge goes only to 1/4 mark. I looked visually for any broken turbo hoses but I don't see nothing. I thinking about pressure testing but I got to get some adapter . Any one had similar problem?
    Thank you.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I had the same noise when the shaft spent inside my turbo.
    I could still drive the truck but it had very little power
    Had purchase a new turbo
  4. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Have you ever replaced your mufflers?
  5. 05vnl670
    165
    60
    Feb 17, 2013
    truck has good power and it don't have mufflers on it, only dpf and src filters.
  6. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    When I took the intake tube off of my turbo, I could see the shaft was bent, and the fins had shaved the sides of the turbo. The turbo also head metal shavings inside
  7. ashtre
    ashtre Light Load Member
    109
    108
    May 9, 2016
    I had similar noise last month accelerating and with jakes on, turned out to be a couple exhaust leaks, one at my cac and one on my flex pipe clamp
    Scooter Jones Thanks this.
  8. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    I take it that it's not a 05 670 truck then.
    Screeching/whistling and low boost, replace oring on turbo outlet and oring on egr venturi tube. Common boost leak areas....
    Fresh clamps are recommend because the V inside them starts to spread and doesn't clamp the same over time.
  9. KB3MMX
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    That would be boost leaks, not exhaust if it's CAC.
    Exhaust manifold or piping with EGR system would be exhaust.. also common leak areas
  10. 05vnl670
    165
    60
    Feb 17, 2013
    I will do the orings and v band clamps on the turbo outlet pipe. I also noticed that the factory intercooler pipe has some metal rings that hold the flex hoses. I found one that I can spin around. I’m sure it leaks there.
  11. KB3MMX
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    They all are free to spin they're not attached but yes they can wear through and leak over time and several hundred K miles.
    Now...if you have the black rings that replaced intercooler hose clamps they are notorious for leaking. Cut them off and replace with constant tension, spring style intercooler clamps...
