D12 Coolant Sensor
Discussion in 'Volvo Forum' started by v6killer, Oct 28, 2011.
  1. v6killer
    v6killer Medium Load Member
    446
    122
    Dec 6, 2010
    ChicagoLand
    I have an Volvo D12 2007 780
    I had the coolant light come on and kill the engine after it appear in the dash, I install an new sensor and four days later it dose it again.
    Yes, the over flow is full
    dose any one have the same problem as I do. Only way around was to disconnect the sensor in question. But, I would like to have the coolant sensor working, so if I ran low or out I would like to know.
    New2D12 Thanks this.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    what a fault code? '07 D12 may be D12D ore D12F, there are ECT (coolant temp. sensor) and CLS (coolant level sensor). What sensor is bad? what a code in MID 128 XXX XXX format?
  4. v6killer
    446
    122
    Dec 6, 2010
    ChicagoLand
    It is the coolant level sensor, looks like I have to keep the over flow bottle full almost to the top to keep the sensor from going off.
    I took the truck to Volvo they said, must be an short in the wire going to the ECM on the eng. I said, you must think am stupid. I told them the sensor in question was not calibrate correctly for the fluid in the over flow tank, the tec. Said, I do not know how to calibrate that sensor, I must call Volvo to get that information. I told them just fix my low beams so I can run my HID lights. Am out of here. With an 325.00 bill.:biggrin_2555:
    JTRUK Thanks this.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    WTF???? this sensor reads yes ore no coolant!!!! it is a switch! S68.Pin EB23 on Engine ECM!!!
    But there are trucks with A54 Coolant level control unit... but as I remember it is used on VN and FH with ISX only....
  6. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Mine is simaliar but doesn't shut the engine down unless, I'm empty on coolant. But does read low coolant on the readout until it get up to around 135 degrees. I replaced the sensor and it didn't change anything. Thankfully it goes out after warms up.
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    it depends on programming
  8. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Those type sensors short to ground through the liquid. The other type is a magnetic float switch with a reference signal to and from the ECM.
    If you replace it and still have problems, then you have wire/connection issues. Like Pablo said, they either work or they don't. If you are getting anything else like works sometimes or it has to do this or that before the light goes out, you most likely have wire/connection issues.
    Do you have a solid ground? Unplug the sensor and test the ground by putting the black probe of your meter to the black wire and the red probe to battery hot. You should have 12.0V. A corroded poor ground will read lower.
    If that checks out, then you can suspect the ECM return wire. Check where the wire goes into the back of the connector. That's the most succeptable spot for one to corrode or the strand wire break. Check the pins in the connector. Next follow the wire out and see if it exposed and rubbing anywhere. It runs straight to the firewall pass through main harness. It should be a relatively short wire.
    A float type coolant level switch sends a 5.0V reference signal from the ECM and the return wire should read 0.5V if everything is working correctly. You can backprobe the wires on them type switches.
    If you have dirty coolant and a dirty tank, you need to do a flush and also clean the tank. The easiest way to clean the tank is remove it and fill it partially with water and Dawn detergent and shake the crap out of it. Then rinse it out good.
    Flightline, yours sounds like you are just short a 1/2-1 gallon or so. The sight glass can be deceiving. When your truck warms up the coolant expands and your reservoir fills up more. That would explain the sensor not being submersed and then being submersed. Drop a stick or something in the tank to get the true level or crawl up there and look down in it.
    I remember when my EGR cooler started going out and was eating coolant. The dealer told me not to put anymore coolant in, the reservoir was full. Not only that, they said nothing was wrong with the truck. I went straight back to our shop and had our mechanic check it. He put 5 gallons in it. Moral of the story is the sight glass is a piece of junk. Coolant gets trapped in it even if the tank is empty. The only way to trust it is to check it yourself.
    New2D12 and JTRUK Thank this.
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Yeah, coolant is color marked and paint may stay on glass!!!!!
  10. nikmirbre
    nikmirbre Road Train Member
    5,376
    9,582
    Jul 27, 2011
    High Point NC
    So where exactly is the sensor located???
  11. nikmirbre
    5,376
    9,582
    Jul 27, 2011
    High Point NC
    I think i found it, its on the underside of the resevoir....
    JTRUK Thanks this.
