Cylinder Heads - Cat C15, C16, C18 and 3406E
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Daniel Otto, Aug 14, 2019.
  1. Daniel Otto
    Daniel Otto Bobtail Member
    I have some doubts about the C15, C16 and C18 engines:
    Do they use the same cylinder heads? The differences between this models are just in cylinder bore and stroke?
    And what about the 3406E with C-15 and C-15 Acert?
    (I’m not from USA and it is very difficult to get information about those engines here)
  3. AModelCat
    154,481
    You'd have to post some S/N's for a more accurate answer.
    There are 16 different prefixes for the C15 truck engine.
    There are 2 different C16 truck engine prefixes.
    There are 3 different C18 truck engine prefixes.
    The 3406E has 7 different prefixes in their truck engine lineup.
    The above numbers don't include S/N breaks within each prefix either.
    Intothesunset and Daniel Otto Thank this.
  4. Daniel Otto
    Thank you for your answer, AModelCat, but I don't have the Serial Numbers..
    I just want to know about big differences in the parts like the oil return geometry or the grooves on the cylinder head bottom face...
  5. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    E model and c model heads will fit on acerts, I know that much, because it is very common to deacert them here with the other heads.
    I better edit, at least some of them will, I am not 100% sure all of them will. The c18 may be a stretch, I have a friend that installed one in his truck, but he just bought a crate engine.
  6. FreightyAK
    FreightyAK Light Load Member
    51
    42
    Aug 7, 2018
    AK
    The e-model and c-15 use the same head. The early c15s (no hyphen) same head as well.
  7. tommygun58
    tommygun58 Light Load Member
    88
    61
    Sep 22, 2015
    East Texas
    Adept Ape on you tube has some good videos on cat motors. Also 3406e on youtube.
  8. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    If you mean KT3406E on Ytube that guy is awesome. 3406c through C15 MBN bridge engine all use the same crank. And acert cranks are very close but different journal, and bearing sizes, and acert use 4 bolt main caps which seems very interesting.
    Daniel Otto Thanks this.
  9. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Rod caps. Mains are still 2 bolt. Throw is different on twin turbos. Jumps from 14.6l to 15.2
    Wheeljack, Oxbow, A5¢ and 3 others Thank this.
  10. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    Thanks. Very interesting to me.
  11. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    From what I understand, journals are bigger and rods are beefier. Something about the block is stiffer too, as it doesn't twist as bad when you put a lot of power to them.
  12. starmac
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    You are talking about the early c, I am talking about the c-15 which is also a 3406.
