Cwt/fsc question
Discussion in 'Flatbed Trucking Forum' started by Clasix1055, Nov 26, 2012.
  1. Clasix1055
    Clasix1055 Even when I'm wrong I'm right
    998
    708
    Jan 26, 2012
    Toledo, Ohio
    Ok follow me here... I just landed a direct contract that pays cwt + %fsc on 40,000# min
    I want to check my math so first to figure cwt pay is my equation corect @ $.61 .... 40,000 x .0061 = 244?
    now fsc equation @ 28% .... 244 x .28 = 68.32? ....... So total load pay is $244 + $68.32 = $312.32?
    I have been trying to figure this out based on some loads that I have done through a broker reconstructing the equation...I don't want to ask the customer and look like a dunce so any help would be appreciated...if you dont know what I mean please dont confuse the situation cause my brain is now fried...
    Thanks in advance
  3. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    If the CWT is 4.00 and the FSC is 25% at 40K then the line haul is 1600.00 and the FSC is 400.00 for a total of 2000.00.
  4. Clasix1055
    998
    708
    Jan 26, 2012
    Toledo, Ohio
    Ok you gave a entirely different equation....is the way I have it figured the correct way to do this because the equations will change
  5. lakelovrs
    lakelovrs Bobtail Member
    35
    26
    Nov 3, 2010
    Yes your math is correct, or at least this is the same way I figure my cwt loads hope it helps.
    Clasix1055 Thanks this.
  6. Clasix1055
    998
    708
    Jan 26, 2012
    Toledo, Ohio
  7. cpape
    cpape Desk Jockey
    2,151
    2,263
    Jul 15, 2010
    Dubuque, IA
    Your calculation is right, but the rate per cwt must be wrong unless you are only hauling the load across the street.
    JDP and volvodriver01 Thank this.
  8. Clasix1055
    998
    708
    Jan 26, 2012
    Toledo, Ohio
    50 miles .......
  9. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    Give them a flat rate at $500.
    For $300 and some change, it's not even worth starting the truck
    volvodriver01 Thanks this.
  10. Clasix1055
    998
    708
    Jan 26, 2012
    Toledo, Ohio
    It was the first load I pulled off the rate sheet .... That may be handled by the company trucks I am not sure ... I was only trying to check to see if I was doing the equation properly
    SHC Thanks this.
  11. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    Remember, that is on any load weighing up to 40,000 pounds as its a 40 mini. Anything over the mini is additional, at that rate per cwt.
