Custom route GPS
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Akkaid, Dec 24, 2017.
  1. Akkaid
    Akkaid Bobtail Member
    48
    31
    Oct 26, 2017
    Anyone know a way to plan your own route, but have it displayed on a GPS or Tablet? I know there are some rather convoluted ways to do this on some GPS devices, just wondering if there is any software or apps that are purpose built for custom routes? I rarely trust the GPS, and it takes me just as much time to verify the GPS route as it would to make my own....
    Thanks yall!
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    Trip maker - then imports to Rand device
    Oldironfan Thanks this.
  4. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    And Garmin has "Base Camp" but either one you'll probably find to be more trouble then worth with all but the most complex routes [for trucking purposes]
  5. Steel Tiger
    Steel Tiger Road Train Member
    2,665
    3,221
    Jun 6, 2012
    Orlando, FL
    Put various stop points along the route you want to take
  6. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    That's probably as good a way as any other (using an external program then pushing to the device as a custom trip) either way you end up with multiple waypoints that become meaningless and confusing as you add more.
  7. LilBudyWizer
    LilBudyWizer Light Load Member
    185
    169
    Most gps devices will let you select frim multiple route suggestions. I would have to question why none of those are close starting with did you set the routing preferences to match what you're actually doing? Generally I only need to route through one intersection. Occasionally I force a route by adding a stop at a truck stop on the route I want. Sometimes I just take the route I want and the gps adjusts accordingly.
    The biggest problem run into is truck restrictions. Like past the entrance to the truck stop or customer is restricted but the gps thinks intersection to intersection is. Often mine thinks the bridges over the interstate next ti truck stop are. It generally it thinks medians can't be crossed except at cross roads. So there's a few specific things where I just ignore it. No, I'm just going to cross that overpass and take the sb entrance rather than nb, turn around and come back. Once sb on the interstate it's fine.
  8. hunts2much
    hunts2much Medium Load Member
    325
    133
    Aug 25, 2008
    It boggles my mind it's almost 2018 and there still isn't a gps device that's in the same league as what I started with in 2008...Microsoft Streets and trips with the truckstops plus add-on.
    Good God it was so simple to drag custom routes with one click or even better right click and draw a box to avoid areas.
    kemosabi49 and not4hire Thank this.
  9. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    It used to be that simple.
    The latest copilot can't seem to do that anymore. They've also taking out the settings for shortest route or practical route. It's now set for shortest.
    I used to recomment copilot but i can't recommend it anymore.
    hunts2much Thanks this.
  10. hunts2much
    325
    133
    Aug 25, 2008
    Give me an updated maps version of streets and trips on a 10" tablet with a truckers atlas and I'd be as happy as could be.
  11. snowwy
    20,527
    13,262
    Jul 6, 2009
    I could be wrong but i think it was posted on this forum that msft isn't making streets anymore.
