Current Idaho 511 App Chain Restrictions and "Chains advised/recommended"
Discussion in 'Questions From New Drivers' started by BeHereNow97, Mar 16, 2022.
  1. BeHereNow97
    BeHereNow97 Heavy Load Member
    955
    1,942
    Sep 15, 2020
    I didn't want to start two seperate threads so I figured I would just ask these two winter related questions in the same thread.
    1. For Washington State, what does "travel chains advised" or "travel chains recommended" mean?
    I have to pass Snoqualmie Pass tomorrow and the Washington 511 app just updated so right now there's no restrictions, but about 10 minutes ago the app had, for Snoqualmie Pass under the "Pass Report" and then "Travel eastbound" as well as "Travel westbound", it said SOMETHING like "travel chains advised" or "travel chains recommended". I should have screen shotted it but it either said advised or recommended, with the key point being that they didn't say "travel chains required".
    So if you need to put on chains for Washington State, the app/the signs on the passes in real life will say "chains required". Then you either chain, park somewhere outside of the chain up areas or if you don't chain and are blocking a chain up area, they will fine you. I understand that.
    But legally speaking, what are the legal ramifications of "chains advised/recommended"?
    I'm thinking that "chains recommended/advised" simply means that the roads are getting worse and the chains are recommended, but the DOT isn't going to stop you/fine you for not chaining. It's basically just a warning sign, I think. Do I have this right or no?
    Probably a dumb question but I wanted to ask anyways.
    2. Is there anywhere, either online or via the Idaho 511 app, that has the current chain restrictions for Idaho?
    I looked on the app and on the desktop version and I couldn't find anywhere where it had the current chain restrictions listed. I know where to look for Washington State 511 app as well as the Oregon 511 site, but I cannot find anywhere on the Idaho 511 app where I can find that information.
    tscottme and mmoon Thank this.
  3. Espressolane
    17,007
    102,650
    Most of the state sites are generally making reference to automobiles. Chances are high that if it says advised, CMV’s will be required.
  4. mmoon
    mmoon Bobtail Member
    Jun 16, 2013
    Idaho 511 click on layers/legend to turn on option for commercial vehicles.
    tscottme Thanks this.
  5. tscottme
    tscottme Road Train Member
    I'd say that your understanding of "chains advised/recommended" is correct. Commercial vehicles are required to carry sufficient chains/traction devices in WA from Nov 1 to April or May 1. However you are not required to use chains unless the state notifies you with a "chains required" statement. WA & OR have 3 levels of chain requirements. 1) commercial vehicles, 2) CMV & private vehicles over 10K pounds, 3) all vehicles. Those are listed in increasingly worse conditions.
    BeHereNow97 Thanks this.
  6. tscottme
    Oregon definitely says "chains required on CMVs". It's NOT implied.
  7. mmoon
    Jun 16, 2013
  8. BeHereNow97
    955
    1,942
    Sep 15, 2020
    Well yeah I know Idaho will use roadside signs for when you need to chain up.
    So I'm guessing Idaho doesn't have a specific section on the app or website that will tell you the chain restriction?
    Instead I'm guessing IF there is a chain restriction, that it will show up on the "restrictions" icon on both the app and the website map, right? Can anyone confirm this?
    There's a truck icon that you can click on the Idaho 511 website that you can't click on the Idaho 511 app. But I think it's the same thing, it lists the truck restrictions. For now the only ones on there are stuff like width limits and stuff like that.
    So again can anyone confirm that if there are chain laws in effect for Idaho, that the Idaho 511 app and the Idaho 511 website will list those chain restrictions on the "restrictions" icon on the app/website? Or will they not list them there?
  9. BeHereNow97
    955
    1,942
    Sep 15, 2020
    Thanks! I know that was probably a dumb question to ask about "advised/recommended" versus "required". I just wanted to ask to be sure though, thank you!
  10. Long FLD
    Long FLD Road Train Member
    11,385
    45,972
    Mar 4, 2015
    If you’re going west and MT doesn’t have chains required then ID isn’t going to make you chain at the top of the hill to go down.
    D.Tibbitt Thanks this.
  11. tramm01
    154,033
    Don’t think that we have any mandatory requirements like other states
  12. tscottme
    It's not dumb to ask questions. A wise man knows what he doesn't know and asks.
