So I deliver to some nasty Home Depot's as a northeast regional flatbed driver. They're in shopping malls, strip malls, or repurposed grocery stores with no docks. There's just no avoiding some of these curbs, islands, and sidewalks. They love putting in the jagged granite/quartz square curbs too not the nice smooth rounded ones. I do my best and make it through most lots without issue either completely clean or "well no missing it just run it over".
The issue I have is sometimes I think I can make it and I inch slowly through and think I just cleared it. Then in my PTI I'm seeing cuts or gouges in a sidewall because I was an inch or two off and some of these curbs are sharp as knives.
So first off, when is a sidewall damage serious enough to warrant a shop visit? The green Bible says something about belt or ply material showing but I have not noticed anything but rubber. Sometimes it's like you took your nail and gouged out a bunch and others times it's a little to medium cut.
Second, if you're not positive your trailer tires will fully clear a curb is it better to try to purposely run it over with the tread? Cleanly running it over (at 2-3mph) seems less risky to the equipment but obviously is rude to customers, unprofessional, and sort of illegal. Then you're risking tearing out chunks of tire tread, but unless you can see steel belt under the portion the curb kept as a souvenir you're good to roll right?
There's no "winning" move but that's the northeast for you.
Curbs and trailer tire sidewall damage
Discussion in 'Experienced Truckers' Advice' started by LeadFarmer, May 9, 2018.
If I'm going to curb it I turn into it and gently run it over. Try to get it to just ride up instead of sliding as it goes.
Be careful not to hit signs and such, and in a parking lot be careful of grass and sprinkler systems.KB3MMX Thanks this. -
Sprinkler heads on an island are mostly going to be in the middle and unless they're actively running I'd have no idea I damaged one... And neither would the customer -
Try to run it over with the whole tread to spread out the weight and reduce risk of damage. Go as slow as possible to reduce risk of belt damage.
What’s the damage look like? A trip to the shop now might save you time later if it blows.
Plop a coil timber in front of the curb so the tire has something to "step" on.
I had my truck breakdown 10 miles from my yard fully loaded. So the company had it towed back. Well the tow truck driver after hooking it all up cut through a closed outlet mall at 5 am. I forgot count of how many signs he ran over while laughing.
BillStep Thanks this. -
