Cummins x15 air compressor intake
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Johndeere8370, Sep 16, 2023.
  1. Johndeere8370
    Johndeere8370 Bobtail Member
    4
    Just bought 2020 x15 with performance 565 and was wondering if the air compressor intake line coming off the turbo is causing issues like I’ve been reading or am I just worrying about nothing. If so what should be done with it?
  3. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    Have seen one engine that was dusted so far from the air leak around the front turbo cover.
    The update is a new cover that has an o-ring to seal it. This is the piece on the turbo that connects to the compressor pipe.
    The o-rings in the connections to the air compressor, have not seen any issues there.
  4. Johndeere8370
    4
    Is that something I should take apart and check?
    Or can I tell from the outside?
