Cummins X15 1,000,000 mile motor?
Discussion in 'Ask An Owner Operator' started by Elroythekid, Jul 30, 2022.
  1. Elroythekid
    Elroythekid Road Train Member
    2,604
    5,655
    Sep 9, 2010
    Halifax Nova Scotia
    So, I have an opportunity to purchase a 2019 W900, studio bunk, loaded with o/o specs, with a 500hpX15 Cummins, 18sp. Has 625,000 miles on it. 1 owner, great shape.
    Price is good compared to everything else.
    What are the X15 weak spots?
    Will it go 1mil miles if maintained properly?
    Any info appreciated.
  3. RunningAces
    RunningAces Road Train Member
    1,263
    2,513
    Jul 2, 2017
    If the person you're buying it from can show oil change and maintenance receipts that would be a big deal. Also, that truck obviously has a lot of miles for a 2019, but how many hours does it have?
    Coffey Thanks this.
  4. Elroythekid
    2,604
    5,655
    Sep 9, 2010
    Halifax Nova Scotia
    He ran bulk tanker with it, empty half the miles. He had all maintenance paperwork. I know the fellow and it was well taken care of. He has some health issues and is done working. Not sure on the hours?
    It doesnt have a pro or blower, all his work was bottom dump, before that he did deck work with it when he first got it.
  5. RunningAces
    1,263
    2,513
    Jul 2, 2017
    He was obviously a hard worker. 135000ish miles a year proves that. If he also idled the truck all day and night though it might have well over 20000 hours on it. I am not a mechanic by any stretch of the imagination but my understanding is that most inframes are needed somewhere between 20000-25000 hour mark.
    bzinger and Elroythekid Thank this.
  6. Judge
    84,422
    Engine will probably be ok.
    Lots of little other things may go bad, sensors, or such.
    Did an inframe at 1,075,254 was platinum inframe plus oil & water pump & new AC compressor plus labor $22,998.95
  7. Elroythekid
    2,604
    5,655
    Sep 9, 2010
    Halifax Nova Scotia
    I can check the hours on it. Thanks.
    Vampire, RunningAces and Rideandrepair Thank this.
  8. Judge
    84,422
    I don’t go over 12k on oil change, 15/40 rotella w/gallon of lucas. won’t use any oil between changes.
    If front seal goes out, it’ll leak oil bad, about 8000 for repair gotta take hood/bumper/radiator whole front cap off engine,
    Sounds different til you get used to it, but tuned right, it’ll run/pull.
    I’ll buy another one.
    Reason for edit: spelling
  9. dirthaller
    dirthaller Road Train Member
    1,012
    11,790
    Sep 22, 2011
    Coloratah
    Cummins recommends going 500,000 before you run the first overhead. If the original owner was dumb enough to let it go 500,000 before the first overhead, I promise you that it won’t make a million before the head comes off!
  10. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    You’re in the right neighbourhood, take that past Boyd’s shop and let him look it over. He’s the best Cummins guy I know down there.
    Vampire Thanks this.
  11. Elroythekid
    2,604
    5,655
    Sep 9, 2010
    Halifax Nova Scotia
    He's the best period. My tuck is headed there tuesday, I have a small leak somewhere underneath, dripping off the bellhousing, it needs a PM done also. I'll have a chat with him then. I'm hoping he sticks around there now that he's sold it, or so I'm told he has.
