Cummins X-15 500hp, full synthetic?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Deezl Smoke, Oct 3, 2022.
  1. Deezl Smoke
    Deezl Smoke Medium Load Member
    458
    288
    Feb 12, 2011
    Hillsboro Oregon
    Hi all.
    So I had some warranty emissions work done recently on my 2021 Peterbilt 567 with the Cummins 500 efficiency X-15. I inquired at Cummins NW about going full synthetic engine oil and they basically evaded the question with the "we can only recommend the oils stated in the owners manual". Ok, fair enough. But what is the opinions or experiences of the members here on going full synthetic in this engine at 250k miles?
    Will synthetics solve or cause more emissions issues? How about other sensors etc.?
    Thanks for any help on this as I need to service the engine soon.
    MartinFromBC Thanks this.
  3. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    First question would be how often do you change ur oil? Full synthetic oil isn't cheap. Unless u are doing the extended drains I wouldn't run it. Maybe go with a semi synthetic.
  4. MartinFromBC
    2,769
    12,476
    Oct 19, 2018
    I only run full syn, regardless of age.
    Oxbow Thanks this.
  5. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    I always ran T6 and changed it at 20K miles…..
    But I wasn’t paying $100 a gallon for it.
    Oxbow Thanks this.
  6. MartinFromBC
    2,769
    12,476
    Oct 19, 2018
    A hundred a gallon.
    I want to be your oil salesman.
    Heck I'll only charge you half that.
    Did you maybe mean a hundred a pail?
    Oxbow and Cat sdp Thank this.
  7. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    On my 2014 ISX 15(2016 recon long block) I use a local oil distributor house synthetic blend that cost me $12.00 a gallon, was paying about $8.00 a few years ago but everything has gone up. I change it about 10-12,000 miles. This last oil changed I went 13,000. Several on here swear with those long interval changes. But I have a peace of mind doing the way I service mine.
    spsauerland, Oxbow, D.Tibbitt and 3 others Thank this.
  8. JonJon78
    JonJon78 Road Train Member
    7,041
    37,561
    Jul 1, 2018
    What type of warranty emissions work was already needed on your 2021?
    Oxbow Thanks this.
  9. MartinFromBC
    2,769
    12,476
    Oct 19, 2018
    I actually do mine by time, not miles, some of my trucks don't run a lot of miles, but pile up the hours.
    Six weeks works.
    Isafarmboy, Oxbow and Diesel Dave Thank this.
  10. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    I’ve never gone by hours, just curious, at how many hours do you service yours and what does that equal to in mile ? I run locally and I don’t let the truck idle much unless it’s extremely hot and/or I’m trying to cool off before I go back to securing my load etc……..
    Oxbow Thanks this.
  11. Deezl Smoke
    458
    288
    Feb 12, 2011
    Hillsboro Oregon
    Particulate sensor. Thankfully they had it in stock. They replaced it, ran a regen, and told me to come get it. If I can find my paperwork, I'll scan it and show it. I believe they said it would have been $1400 if not under warranty.
    JonJon78 and Oxbow Thank this.
