I have an n14 recon crate motor I'm wondering if anyone can run the serial # and tell me the specs? 60511847
Cummins serial number lookup site or resource?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Kw Owners Club, Jan 4, 2019.
Cummins QuickServe Online
Try this link. Cummins Engine info.Kw Owners Club Thanks this. -
Cummins recon engine information is vague as all get out. No parts, nothing. Your better off going with the trucks original engine serial number. Most recon engines are universal by application, especially older engines. Software version should get you rating if that's what your after. Just need a hook up is all.
Good luck.spsauerland and Kw Owners Club Thank this. -
Engine data plate says N14-500e. No cpl or software listed. Build date 6/2000
Yeah, it does not show the cpl. For 500hp I assume it's 2592. Get a serial from another 500 or 525hp and order the parts needed
Could someone tell me what year my 4bt is? 48107434
Thank you!!!!!!!1 -
Trying to identify the engine in my loader. ESN 20113061
build date June 1972 ?
Was told engine came out of a generator.
Problem is no fuel getting to engine shut off solenoid valve. Low pressure pump is good, replaced and bled fuel filters.
Thanks
