Cummins oil change intereval x15
Discussion in 'Peterbilt Forum' started by Z800xp, Apr 9, 2020.
  1. Z800xp
    Z800xp Bobtail Member
    20
    Feb 26, 2019
    Cummins suggests changing the oil at high mileage intervals based on mpg for x15 engines. Seems like a lot of miles on an oil change. What is everyone else doing? A lot of you will probably say do it more often but don't want to if it can be prolonged safely.
  3. Dodsonf855
    Dodsonf855 Bobtail Member
    25
    22
    Mar 15, 2020
    South arkansas
    12-15 thousand miles..... it’s worth it
    stillwurkin Thanks this.
  4. ast26909
    ast26909 Medium Load Member
    408
    264
    Mar 1, 2018
    Every 3,000 miles. Seriously, changing engine oil more often doesn't really help it last longer but using the right oil and changing at the right intervals will make a HUGE difference on the wallet and help conservation.
  5. AModelCat
    158,799
    Well ask any ISX owner how their cams liked extended oil change intervals. I see no reason to trust what Cummins says for service intervals after that even with the X15 being a different engine.
    bzinger and Dave_in_AZ Thank this.
  6. ast26909
    408
    264
    Mar 1, 2018
    A defect on ONE engine does not dictate the laws of physics.
  7. AModelCat
    158,799
    Well if you think going 1,000+ hours on oil is ok, have at it. To me, 500 hours max. Oil and filtration have not advanced a whole lot in the last 10-15 years.
    Dave_in_AZ Thanks this.
  8. ast26909
    408
    264
    Mar 1, 2018
  9. Wespipes
    Wespipes Road Train Member
    1,037
    1,816
    Jul 14, 2019
    Get you a bypass filtration system. Change filters every 12-15k. Send oil in for testing. Most go around 80-100k miles till it needs to be replaced
  10. JonJon78
    JonJon78 Road Train Member
    7,151
    38,952
    Jul 1, 2018
    80-100k? That's insane.
    You got pictures of the filtration system you put on? I would like to see how it looks since we have the same trucks.
  11. Dave_in_AZ
    386,014
    I do my ISX-
    Engine oil
    Oil, fuel, fuel water separator filters
    Chassis lube
    every 20,000
    $300 give or take.
    Coolant filter and air yearly.
    New camshaft installed = $5000 or 17 oil changes
    I'm at 700K miles
    JonJon78 and bzinger Thank this.
