Cummins ntc 335
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Briggs647, Jul 4, 2017.
  1. Briggs647
    Briggs647 Bobtail Member
    16
    Jul 4, 2017
    1. I just purchase a 69 w923 it has a cummins ntc 335 I was just wondering if anyone on here knows much about the engine . Thanks
  3. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    An NTC 335 Cummins was a 290 that someone rebuilt with a 350 fuel pump and injectors and turbo. without cpl numbers I would go out on a limb and say it is probably a small cam engine originally built at 290 hp specs
    Shock Therapy Thanks this.
  4. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    There were factory built 335s.
    OP what would you like to know about it?
  5. Briggs647
    16
    Jul 4, 2017
    Are they good motors ? Were there a lot of problems with them and did they have a glow plug mine looks like it used to have one but they capped it off
  6. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    were good motors but never had a glow plug
  7. Briggs647
    16
    Jul 4, 2017
    Ok thank you I appreciate the info
  8. SmokinCAT
    1,773
    1,487
    Oct 20, 2010
    No glow plugs, it may have had intake heaters but they are direct injection.
    Besides being a small cam there isn't a whole lot of difference between that and the newer big cams, they made some changes to to the crank and it likely has higher compression pistons and advanced timing, but those engines didn't run a lot of fuel.
  9. OLDSKOOLERnWV
    17,806
    268,402
    Had a 335 in my 1973 KW Cabover back in the 80's. Did a good job. And no it didn't have glow plug. Take care of it and it will do what you ask of it.
    MACK E-6 and Oxbow Thank this.
  10. Briggs647
    16
    Jul 4, 2017
    Alright thank you guys for the help it's my fist truck so I'm sure there will b a lot more questions haha
  11. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Cummins is a steady RPM engine. Not so much torque or horsepower. It's roots actually come from the bigger engines that drove ships at sea a long time ago. It likes to run all day at 65 or whatever provided you had the gearing and final drive ratio to keep it moving in the area you are in.
    I pretty much exhausted what I know about this engine, not the 335 in particular, Ive run a number of engines below and above that rating over the years. Some were quite... obstinate in it's habits let's say...
