Cummins n14 injector issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kenllah, Feb 1, 2021.
  1. Kenllah
    Kenllah Light Load Member
    226
    113
    Nov 17, 2017
    Have an n14 celect plus. Slight random miss at idle. #4 injector failed injector cut out test ( no change to engine operation when #4 shut down. Swapped #3 with #4 injector. Problem still in # 4 hole.
    Truck definitely idles a lot smoother before I open insite. Once I hit the start button without selecting any particular injector it has a bit rougher idle but it doesn't seem to miss.
    New pistons and sleeves last year. New cam shaft this week. New cam followers this week.
    Ready to send ecm out for testing unless there is something else I'm missing.
    Replaced all Injectors last year with remans chasing this problem... still chasing
  3. AModelCat
    154,359
    Did you check the all of the injector wiring? From injector to ECM?
  4. Kenllah
    226
    113
    Nov 17, 2017
    Just look at it or am I checking voltages or what?
  5. AModelCat
    154,359
    I'd start with a visual check for obvious damage. Definitely check the pass-through connectors. The seals can break down and oil can get into the wiring. If that checks out I'd check continuity from ECM to the problem injector.
    drive-away2020 Thanks this.
  6. Kenllah
    226
    113
    Nov 17, 2017
    Would you consider #4 the problem injector or does the computer do some sort of goofy balancing act and the actual problem could be an over fueling injector somewhere else? Would it be wise to swap 1&2 then 5&6 to see if anything changes or is that chasing unicorns?
  7. AModelCat
    154,359
    I'd say if the problem stayed in #4 even after swapping the injector that the issue is likely related to the #4 cylinder and not the injector.
    DUNE-T Thanks this.
  8. Kenllah
    226
    113
    Nov 17, 2017
    Ok. I'll check the harness and pass thru.
  9. J.R.
    J.R. Light Load Member
    60
    154
    May 17, 2012
    WI
    Mine would do same smooth out on insite, per Wore out I started adding 1 gal 2 cyl oil to 100/150 fuel idles like a dream .
  10. drive-away2020
    drive-away2020 Light Load Member
    68
    260
    Aug 17, 2020
    It’s a little late now. But if you ever do buy new injectors, make sure to get the PX remans and not the RX remans. The PX has a way better rebuild quality and aren’t prone to failure like some of the RX remans
    Kenllah Thanks this.
  11. Kenllah
    226
    113
    Nov 17, 2017
    I'm guessing that's the part # you are referring to.
