Where is everyone having the best luck getting ECM From? Midwest ECM IN Colorado? SIA in Illinois? Diesel ECM exchange in NC? Cummins said it’s obsolete part number. Gotta go aftermarket. Peterbilt said same thing. I’ve heard bad things from ECM KING in Texas. I believe my injector driver is bad in both ECM’s I have. Replaced wiring harness, EPS, pass through connectors, all 6 injectors. The problem seems to be moving. New Injector 5 failed, replaced it, the new #4 went down. Now I’m showing new #3 is down. Can’t be 3 out of 6 new injector failures. I know if you have injector failure it can knock out ECM injector driver which is what I’m thinking happened before I put new injectors in. Thoughts/Suggestions? Can’t find any bad wires or ground issue. But if anyone knows of something I might have missed, I’m all ears. Thanks in advance for help
Cummins N14 ECM 3408300
Discussion in 'Ask An Owner Operator' started by LoJackDatHo, Dec 20, 2020.
What micron fuel filter are you using? I ran a 5 micron when I had a n14.
@blairandgretchen had a ecm repaired on a 12.7. Don’t know if they do n14.
@spsauerland may have some suggestions.
@SmokinCAT may know someone who rebuilds injectors.blairandgretchen and LoJackDatHo Thank this. -
N14parts.com, that's where I bought mine. You can also send yours for a check-up and repair to Midwest Ecm in Colorado, will be way cheaper
Coffey and LoJackDatHo Thank this. -
062 Thanks this.
Cummins is dropping support for the N14 ecm. They have a bulletin out to convert it to a supported cm876 ecm but it requires changing the camshaft and some sensors/brackets.
I have used midwest to repair n14 ecms in the past.blairandgretchen and 062 Thank this. -
Just so everyone knows, I tried a set of injectors remanned by Ambac International out of South Carolina I believe. 2 year warranty supposedly equivalent to the PX Cummins reman not the RX Rebuilt
I didn’t know that. I’ll check into it. Thanks for the infoblairandgretchen Thanks this. -
Little update. Truck being put on CPU today. Thinking that running any injectors other than Cummins might be the problem. Getting a lot of feedback from guys saying the aftermarket ones just aren’t up to snuff. But will see later today for sure
I used SIA once. Not a fan.
I was satisfied with Midwest.
I was broke down in Des Moines, IA. with an oversize load. The dreaded "111" code. I called 3 truck dealers for prices. They all said Cummins had the only one in Town.
I got a taxi to Cummins, $3,500.00. I told the salesman Truck Dealer had a lower price. He said. We aren't here to support you, we're here to support the dealers.
At least they sold me the ECM and programmed it right away. I remember only waiting about an hour for the ECM to get a taxi back to my truck at the Truckstop.LoJackDatHo Thanks this.
