Cummins N14 Celect Plus
Discussion in 'Ask An Owner Operator' started by flat-step, Dec 11, 2015.
  1. flat-step
    flat-step Light Load Member
    96
    21
    May 11, 2011
    Hello all,
    I'm looking into buying a cummins n14 select plus tomorrow. Never had this motor in any of the trucks i've owned before. I would appreciate if someone can shed some light on what things to look out for other than the usual oil/water contamination, misfire etc.
    Thanks
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    If your hear it chirping, almost like a bird tweeting, then it may have a broken head bolt, or in my case a head gasket ready to let go.
  4. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Oil leaks.. Front crank seal, accessory drive seal, and on the drivers side the cam followers.
    blairandgretchen Thanks this.
  5. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    Does the N14 have the oil leaking wiring harness grommet at the back of the head like the M11?
  6. 062
    062 Road Train Member
    6,142
    33,155
    Oct 20, 2013
    No
  7. KenworthGuyNH
    KenworthGuyNH Road Train Member
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    Even with minor issues, the N14 is a solid powerplant. Economical to rebuild and easy to work on. What HP/torque rating is it?
    blairandgretchen, KB3MMX and MJ1657 Thank this.
  8. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Pretty good engines. They seem to be prone to leaks of all sorts lol. They have good power and can get really good mileage if driven right.
  9. 062
    6,142
    33,155
    Oct 20, 2013
    They like clean fuel,cummins spec.is a 10 micron filter. The guy before me was using 16 micron,he was dropping injectors every two years like clockwork.
  10. DUNE-T
    DUNE-T Road Train Member
    6,874
    16,589
    May 10, 2015
    Detroit, MI
    I have two of these, one with 1.6 mil and another with 1 mil. Both are 500hp and both get 6.5 mpg with 40k loads and driving 65-70 and 7.5 mpg with light loads. The do leak at camshaft, costs about $1200 to fix. PAI makes good aftermarket parts for them, for example oil cooler costs $300 compare to $800 at the dealer. If something happens on the road you can go to anybody, any truck dealer or private shop and they will fix it. So yeah, go ahead and get it
    blairandgretchen and KB3MMX Thank this.
  11. DUNE-T
    6,874
    16,589
    May 10, 2015
    Detroit, MI
    What part number and brand do you use? I don't even know what kind do I have
