Have an old Cummins KTA 600 which appears to have a major oil leak from under # 3 cylinder head. How involved would it be for me to fix this myself?
The engine sounds good otherwise. I dont know the history , but i am only going to be using it from time to time as a backup truck. Id like to try and stop this leak before i drive it too far and test the rest of the motor out on the highway.
Any advice on these old motors would be much appreciated. Cheers
Cummins KTA 600 - Leaking oil under cylinder head?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by oldson81, Apr 9, 2016.
Page 1 of 3
CK. on outside of valve cover for a broken head bolt, pull valve cover and look for a broken head bolt?
6 individual heads.
Piece of cake.
K blocks are the bomb. -
The leak is on the turbo side / your passenger side. Yep , being individual heads I was hoping it could be pulled fairly easily. I'm a mechanic by trade here in Australia never opened up any big cummins motors. I should be able to get my head around it. Anything I should be looking out for?
He said KTA 600 and I just woke up!! Post a couple pics of it, if you don't mind.
Posted a photo above. After half hour idling the oils dripping on the ground!! Doesn't seem to be rocker covers. Almost certain it's leaking from under the heads.
Just a thought did you pull the valve covers and check the head bolts torque?
Page 1 of 3
