Cummins ISX Turbo Actuator
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by RGVTrucker956, Aug 16, 2019.
  1. RGVTrucker956
    RGVTrucker956 Bobtail Member
    27
    4
    Sep 17, 2016
    Recently been having problem where truck loses complete acceleration, starts shaking & blowing white smoke. Towed to shop, changed gear fuel pump, Fuel shutoff solenoid. Test drove it for a while, hauled a load and next day started doing it again. Then changed turbo actuator & it’s been running fine, but is it normal for the actuator to be closing & opening in idle. Scared to put a load on it & have it break down again.
  3. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    They live longer if you use a turbine blanket that shields the heat off the actuator head...
    RGVTrucker956 Thanks this.
  4. wtokhi
    wtokhi Light Load Member
    251
    115
    Nov 3, 2017
    what isx is it?, is it the vgt electronic turbo actuator?
  5. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Looks like an 870
    spsauerland Thanks this.
  6. bluerhino
    bluerhino Light Load Member
    107
    7
    Mar 10, 2013
    Good evening all i have the same actuator looks like mine is stuck can just replace the actuator only please need your expertise advice thanks
  7. me myself and I
    me myself and I Heavy Load Member
    731
    312
    Oct 5, 2009
    vernon hills,Il
    It can be changed. Do it soon or your turbo will seize
  8. Dave_in_AZ
    370,514
    Man I have the VGT. Sometimes I think it's gonna turn into a stalk of bananas.
  9. bluerhino
    107
    7
    Mar 10, 2013
    Where is the best place to buy
  10. pushbroom
    1,777
    7,253
    Sep 1, 2012
    Cummins. 1yr warranty
    spsauerland and bluerhino Thank this.
