cummins ISX SCR/DEF service rrquired
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mitmaks, Apr 18, 2016.
  1. mitmaks
    mitmaks Road Train Member
    2,542
    2,064
    May 16, 2014
    What does this usually mean?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Could just be that the def pump's filter is plugged. Could be that the Diesel Oxidation Catalyst is plugged or damaged. Could just be the NOX sensor, etc
  4. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    It could mean many, many things.
    Could be a plugged DOC face. Which means there's typically a cause... often, the dosing injector will either leak, dispense too much fuel, or the aftertreatment fuel shutoff valve will #### up.
    There could be cracking in the DOC face or the DPF honeycomb. That'll cause problems which will trigger a DTC.
    Could be a problem with the aftertreatment differential pressure sensor, which might be a broken wire, a plugged tube, or a bad sensor. If it's not getting to temperature during regens, that could be for a number of reasons. Too much fuel or a restricted airflow (due to blockage in the air intake or a clogged air filter) and cracking in the DPF (on Cummins trucks which use the 90 degree outlets, cracking at the base of the neck is a common problem).
    It could be a problem with the DEF doser, the DEF sending unit, the DEF heater line, etc. For the SCR, it could be catalyst conversion efficiency... that DTC can be caused by a faulty nox sensor (and there should be such a code corresponding to it) or poor air intake. If you get a code of "SCR Mechanical Calibration Out of Adjustment" (or something like that.. I don't remember what it is ver batim), you're replacing an SCR. Seen a lot of Cummins SCRs need replacement within the warranty period.
    Either way, you're going to need to get hooked up to Insite and have DTCs checked. That message on the dash is a general warning, and, unfortunately, doesn't get as specific as you'd need it to be for you to try troubleshooting it yourself.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Is this a fault on your dash? If so, what is the exact fault?
  6. mitmaks
    2,542
    2,064
    May 16, 2014
    SCR/DEF SERVICE REQUIRED
  7. Lyle H
    Lyle H Road Train Member
    1,289
    2,931
    Apr 16, 2014
    One thing witching hour forgot to mention is that it might just be a communication problem between the computers and end up clearing the code all by itself.
  8. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    Hard to say without fault code so much with these systems
  9. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,124
    Jun 3, 2015
    What year is that engine? Would like to know what the mileage is and engine time is on it too...just curious.
  10. mitmaks
    2,542
    2,064
    May 16, 2014
    Truck is 2013 T660 410000k miles
  11. truckthatpassesyouby
    1,876
    6,124
    Jun 3, 2015
    You should definitely let us know what the issue was when you get it checked out.
