Cummins ISX Fuel Pump
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by etianlongoria, Feb 25, 2020.
  1. etianlongoria
    etianlongoria Bobtail Member
    Hi, I have a 2012 Peterbilt 386,with a Cummins ISX, but this truck came with a engine that was manufactured by Cummins ReCon ,with date 01/18/16, now I have a few questions, is this fuel pump from 2016 also?I have to be worried with this fuel pump?, any way to know if this fuel pump has ceramic or steel plungers?
  3. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    If it’s a Recon, it’s probably because the original fuel pump made a window in the original block and the entire engine was replaced by Cummins.
    The Recon most likely has the updated fuel pump with the steel plungers.
    Hulld and bzinger Thank this.
  4. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    Could have steel plungers but don’t let your guard down.
    How many miles?
    I am told they still have had some failures with the updated pump.
    spsauerland Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    I would most definately check or replace the oil bypass valve and make sure it's the updated one. Cheap insurance if you ask me. Tough call being a 2016 rebuild.
    Dave_in_AZ and spsauerland Thank this.
  6. W9SMJ
    W9SMJ Bobtail Member
    I'm looking to buy a 2017 Kenworth T680 with a Cummins in it. Dealer tells me the fuel pumps in the 2017 models had been updated and were not a concern. Is this correct?
  7. Dave_in_AZ
    369,690
    Yes. And it cost an earth shattering $250 to have the ceramic ones changed to metal at Cummins in the old engine.
    I had almost 700K on mine before I swapped them.
    The 2017 also has an extra piston ring that eliminates carbon packing.
  8. drive-away2020
    drive-away2020 Light Load Member
    68
    260
    Aug 17, 2020
    Yeah, go ahead and get those plungers checked and or rebuilt ASAP.
  9. Bigtruckdrivah
    Bigtruckdrivah Light Load Member
    186
    224
    May 31, 2020
    Is this something a older ISX suffers from too? I have a 2003 IH with a ISX
  10. drive-away2020
    68
    260
    Aug 17, 2020
    No. This is an issue in the 2250 and 2350 series motors. Which started in 2012 maybe late 2011
    Bigtruckdrivah Thanks this.
