Cummins ISX DOC REPLACEMENT
Discussion in 'International Forum' started by redcentury07, May 18, 2014.
  1. redcentury07
    redcentury07 Light Load Member
    63
    7
    Aug 22, 2011
    Los Angeles, CA
    Hi guys, just bought a 09 prostar wid 600k miles and had the Warn Engine * light checked. A mechanic troubleshooted it and came back saying I have a bad DOC. He also mentioned that it would be a good idea to replace my DPF as well. Anyone else run into the same problem?
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    DOC does not last forever and will need to be replaced at some point in time. 600k miles is still somewhat young, but it depends on how healthy of a life it had. The DPF will need to be cleaned every so often, but should only be replaced if needed. During cleaning, they can measure how easily air flows through. There are specs for this. If it develops too much back pressure it is junk. It is not a "good idea" to just replace one on a whim. It should be tested/cleaned. If not already, you will find out they are very expensive!!!
    Dave_in_AZ and CellNet Thank this.
  4. Heavyd
    7,749
    6,184
    Feb 4, 2009
    If everything is coming apart, I wouldn't be afraid to replace the sensors though. They do take a beating during disassembly.
  5. redcentury07
    63
    7
    Aug 22, 2011
    Los Angeles, CA
    Ya, its gonna cost me roughly 5k to replace both, but should i just run the truck a few thousand miles first or not risk it. Also there was some oil from the crankcase. It was last changed in 11/13. The mechanic said there is no blow by so thats a good sign. Is that something I should be worried about?
  6. Heavyd
    7,749
    6,184
    Feb 4, 2009
    I would replace the DOC. There is no test to check the health of the DOC catalytic performance once it is removed. All you can do is look at it and see if it is damaged. If there are regen temp issues and troubleshooting pin point a lazy DOC, then replace it. The DPF only gets more and more plugged throughout it's life. It can be successfully baked and cleaned out and returned to service. You need to make sure there are no cracks and it still passes the DPF flow test I described before. I would send it out to be cleaned and tested. If it is ok to reuse, then reuse it! No need to spend a couple thousand bucks if you don't need to. I would replace the sensors and have a new aftertreatment injector installed. Weak or lazy aftertreatment injectors are one part that can lead to this trouble in the first place.
    Dave_in_AZ and QUALITYTRUCK Thank this.
  7. redcentury07
    63
    7
    Aug 22, 2011
    Los Angeles, CA
    Do you know how much it costs for the DOC alone and how long it takes to send out the DPF for cleaning and baking?
  8. Heavyd
    7,749
    6,184
    Feb 4, 2009
    The DOC is generally a bit more expensive than the DPF. But they are close to the same cost. DPFs are cleaned in specific cleaning machines. These machines are very expensive, and so not every shop has them. It depends on your location as to who has one and how far away they are. For a full cleaning, it takes a full bake. Full bakes take 8 to 12 hours to complete depending on the type of cleaning machine. Depending on all that you could expect it to take 24-48 hours to get back.
    Dave_in_AZ Thanks this.
  9. redcentury07
    63
    7
    Aug 22, 2011
    Los Angeles, CA
    Would it be any good to have both sent out to get cleaned. DOC AND DPF?
  10. Heavyd
    7,749
    6,184
    Feb 4, 2009
    You can try that, for sure.
    redcentury07 Thanks this.
  11. al easley
    al easley Bobtail Member
    24
    8
    Dec 25, 2012
    Get both cleaned and check the exhaust piping , from the turbo to the after treatment filters . There is a flex pipe 2-3 feet behind turbo that will leak and throw a doc code . Best way to see if it's leaking , do a park'd regen ,if you see white smoke under cab it's leaking
