Cummins Isx crankcase pressure code
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Tiny T700, Apr 21, 2020.
  1. Tiny T700
    Tiny T700 Bobtail Member
    I got an cel on my Isx motor and the code read "Crankcase Pressure " . I took out the old filter wich were really bad and full of oil and replaced it with the 'no maintenance ' newer one. Started it up and the cel was gone. Drive it for about 30miles and it pop up again . Truck runs normal and no overheat or oil pressure issues. Any advise off where else the problem might be ?
  3. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Wiring to the crankcase pressure sensor is probably faulty. Sensor is in the top LH of the filter assembly. Pull the loom off and inspect the wires, also give them a pull test, lots of times they are broken internally an just stretch out and snap. Dealers will sell a pigtail and pins for it. P/N 5299153
    This is providing the current check engine light is still for the crankcase pressure. Might be worthwhile to get it on a laptop so you arent chasing your tail
  4. Tiny T700
    Thanks I will check the wires before i take it for diagnostics.
