Cummins ISX coolant loss...
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dmkberger, Sep 26, 2018.
  1. dmkberger
    dmkberger Bobtail Member
    7
    Sep 26, 2018
    I am the husband of the Comptroller of a Fire District in Arizona, my wife tells me about one of their fire trucks that is using two gallons of coolant a week. It is a 2010 KME with the Cummins ISX and I am trying to find a bulletin or campaign about this issue.
    The facility that works on the KME told them the coolant loss is a known issue and I, having been out of the field for about ten years due to a debilitating stroke have not been able to find any information on this engine and the coolant loss.
    Any help would be greatly appreciated,
    Thanks,
    Dale, aka dmkberger
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    2010 is a bad year. But most isx have similar issues.
    It could be a head gasket, or egr cooler, or liner issue, or perhaps a DEF injector.
    @Justrucking2 can give you some pointers to look at.
  4. dmkberger
    7
    Sep 26, 2018
    Thanks, I am looking for Cummins Campaign or Bulletins with the coolant loss as their basis.
  5. Oldironfan
    5,777
    5,541
    May 22, 2017
    They have updated the cylinder with APR kit.
    And the emissions system is on recall right now.
  6. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    While there is no direct campaigns that would apply to your complaint of coolant loss, the egr cooler is the most likely culprit. If you provide a good engine serial number we can see exactly what you have and can key in on tsb's that pertain directly to your engine in question.
    You can also search yourself with a free trial on QSOL.
    Cummins Inc. :: QuickServe Online
    fargonaz, spsauerland and Dave_in_AZ Thank this.
  7. Dave_in_AZ
    369,846
    Two gallons is a lot. If it's going in the crankcase or exhaust they are ruining the engine.
    F the bulletins, and Internet, take it to Cummins or a shop, before the engine is toast.
    Goodysnap Thanks this.
  8. dmkberger
    7
    Sep 26, 2018
    The unit is in service right now and needs a liner and head gasket, as far as I've been told so far. I will find out more tomorrow at the Bored meeting, I mean Board Meeting... if you've ever been to one than you will know that the first spelling is what it really is... I've been told the EGR cooler is what is at fault. I can get an engine serial number tomorrow at the Bored Meeting. We'll go from there, I appreciate the help. I told my wife to tell the Chief to take that unit out of service and get it into service ASAP. He did and the service facility has said that the liner is toast and the head gasket is also bad. I have to see the service order to tell you more about what is going on... I've been told that this is a known problem with the Cummins ISX, that's why I am trying to find out as much as I can before speaking to the repair facility... Thanks Dave. What part of AZ are you in, I'm in Lake Havasu... Dale
    Oldironfan Thanks this.
  9. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    If the head gasket isn’t the fail and the egr cooler failed the leak test then I don’t know why the are trying to sell you liners and a head gasket, unless the motor hydro locked. That’s a big job on an isx. Radiator has to be pulled, cams get pulled out, head has to come off, oil pan gets pulled, the pistons get pulled, your looking possibly at cutting counterbores, replacing a head. Rebuilding the motor at that point.
    If the egr cooler is failing the leak test then I think they’re trying to sell y’all on a big job. Idk... idk If that internal coolant loss has caused internal damage though. If it hasn’t hydrolocked yet it could still be good maybe. They should of pressure tested it with the oil pan off to watch for coolant coming down the liners
  10. CraigInReston
    CraigInReston Light Load Member
    137
    134
    Apr 6, 2017
    First... find out if leak is internal or external. If external it could be blowing out the serge tank (rad cap). That's usually BAD. You have compression inside your coolant system. Usually a blow head-gasket, dropped cylinder liner, or cracked head (over-heated). In rare cases, the fault is in the turbo or the air compressor (but very rare). You will also have signs of oil/coolant cross-contamination. Look for oil in coolant and vise-versa. If you have the original EGR cooler (usually still painted red) and no external signs of leaks, look at your exhaust. It will be white and smell sweet like coolant.(this can also be the above mentioned as well) Unfortunately, any coolant loss, other than an external leaking hose/pipe/radiator is usually very bad news for your engine. If it just started losing coolant, stop driving it immediately and get into a certified Cummins repair facility. The longer you drive in this condition, the more you risk extensive internal damage. Sign on to Cummins Quickserve.com (you'll need engine serial #) and you can find out just about anything there.
    Hope this helps.
    p.s. A member here called Heavyd, is extremely familiar with Cummins engines.
    Heavyd Thanks this.
  11. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    EGR coolers are 100% failure. Head gaskets usually cause compression/pressure in the cooling system and push coolant out of the reservoir. I highly doubt you need a head gasket and liners.
    mhyn and Justrucking2 Thank this.
